Could Use Advice re replacement Battery
One, always use two buckets when washing, one with the soapy water, the other with just water to rinse you wash mitt in before dipping in the soupy one again. Easy way to prevent any debris scratches. And a leaf blower is a great way to dry them also, just don't to close or your scratch it with the plastic end of the blower.
BTW, how are you feeling?
Phil, use an OEM. As to the tender connection. The small nuts on the post connections are a size 10 mm I believe. I was able to put an additional nut on it after putting on the connectors for the plug in tender. If that doesn't make since I'll take pictures!
So, let's say it means a Delco. (or whatever passes for Delco these days) who sells them besides the Chevrolet dealers (presumably)? Yes, Mike, those little 10mm securing screws/bolts work very well on my original unit.
Thank you... Oh, now that I think about it, if I use a non-OEM battery, can I be considered to be a modified entry in the show next month?
Slowly getting better, not getting much sleep though. Wearing this tortoise shell like thing to help my spine heal makes it difficult. Only take pain killer before bed. Got the Vette back in the garage, will be parting it out in a month or two...
Hang in there John. No need to rush it.
Here's one for you Mike!
http://www.corvetteblogger.com/2016/...eek-speedfest/
Or maybe it was a mile before I caught you
Maybe I didn't catch you ?
Keep a positive attitude and this too shall pass... Just glad you're still with us and mostly in one piece!
Thanks Aaron, I do have a positive attitude for the most part though I get pretty bummed when I think of the Vette. Still boggles my mind how the rear stepped out like that. Never done that in 3rd before. Oh well, at some point I'll have another just like it back in the garage. Think I'll stick to better tracks with proper modern run off room also...
It's usually better to head down the day before and grab one of the hotels by the track near I-5 so you are fresh the next morning.
Just my .02
Only Phil could get this many posts on a battery replacement. Red Top Optima for me. Had them in 2 Corvettes and never had a lick of trouble with them. If the OEM one I have now in the C6 fails, it'll get a red top.
