C6 - Did you know this
C6 of Year Finalist (stock) 2019
Did you know this or have you tried it?
1.
While in Track Mode 1 or 2, the maximum G value
achieved during the current ignition cycle can be
displayed by pressing and holding the PAGE button.
The maximum G display will be shown until the
PAGE button is released. The maximum G value
display will be identical to the normal G value
display, except the maximum G gage digits (X.XX G)
and corresponding G gage bar will overwrite the
current G value.
Note that the above process does not display the G-meter result by itself. It's on the bottom of the display, along with all the other things that are normally displayed on that page. When you hold the PAGE button long enough, the displayed 0.00 of the G-meter will eventually change to whatever that highest G-meter reading was.
Someone said you have to hold at least 5 seconds after current run and while engine is still running?
2.
"If you want to splash or lube engine after oil change(or otherwise) press gas petal to floor which shuts down injectors and hit start button engine will crank but not start."
Was hoping someone has tried this one before I put my Vette through the wall and into the house.
1.
current G value.
2.
