370ci LS motor and trans for sale
I have this listed on LS1tech but figured it wouldn't hurt here either. Motor and trans were in a 2000 GMC Jimmy.
The LS2 TB and torque rush link module are also listed for $300 for both or 220 TB and 120 for the link.
Engine is 2004 LQ9 block 4.030. Engine machine work was done at shark racing engines in Sedro Woolley, WA.
BTR 660 lift platinum dual springs, BTR SLR lifters, BTR trunion upgrade
L92 heads recent head work done (valve job and dual spring install) at Browns auto machine in Marysville WA.
LSA valve covers and coils
Cam is a cammotion 224/230 595/595 LSA 112 - good blower cam if you decide to boost it.
motor has right at 30k miles with the cam swap(10k miles on cam) done at a little over 20k miles.
transmission is a performabuilt lvl2 with a 2500rpm stall converter.
Engine has GM hot rod pan and comes full with corvette accessories alternator, power steering pump, LS3 intake, injectors and LS2 TB. Will also throw in the torque rush module to run with a truck harness.
Id like $3500 for the complete motor w/ ecu (blue/grn connector) if you want it.
$1500 for the transmission with Longs Tru-cool 40k cooler.
$5000 for the engine and transmission. For a few more $$ id throw in HPtuners pro (motor ecu unlocked, has 2 available credits) and an ecu afm1600l (upgraded AFX)wide band.
Don't be afraid to make an offer. I am willing to deliver as far south as Portland.
new 0 miles so clean
transmission cooler size
cam and header upgrades 05/14
current sound with black widow mufflers
