Shop to helicoil starter threads
Inside starter bolt stripped and apparently allowed the outer bolt to flex enough to break at the top thread. Spent today trying to extract the bolt - not happening...and the inside hole is stripped regardless.
I don't think I can do the helicoil myself given very limited working height on my Race Ramps, so I'm going to bite the bullet and let a shop do it.
My go-to shop has been Corvettes of Auburn, but but if anyone has a solid, experience-based recommendation for a shop closer to Monroe, WA I am all ears
Thanks!
Thanks!
Jim Green's Speed Shop has been around since I believe the late 60s although not in Monroe where they have been for several years now.
www.jimgreens.com
www.jimgreens.com
I'll give 'em a call.
Thanks!
Oof...4 hours labor and $450 later, I have threads.
I don't feel quite so bad about giving up and taking it in, given that kind of struggle with it on a hoist...
They want 8.5 hours (at $104 per) to replace the valve springs and trunions on the 2002 Z06 I recently got, think I may just do it myself. Seems a bit excessive to me....
Having done the valve spring and trunion swap personally, I'm not sure that price is way out of line. Getting all the stuff off the covers and back on is a couple of hours, plus getting all the plugs out. Then the CompCams tool on each cylinder...yeah, I'm not sure that number is completely nuts.
If you decide to do it yourself let me know as I have the P/Ns for seals, etc., the CompCams valvespring compressor, air fitting to hold the valves up and if you're doing the CompCams trunion bushings I have the Summit Racing pilot tool for that as well.
They tell me they use Lil Johns stuff:
https://www.liljohnsmotorsports.com/...pring-kit.html
https://www.liljohnsmotorsports.com/smith-brothers-ls-bronze-bushing-trunion-upgrade-kit.html
They say they've never had a failure with his stuff.....
I'm assuming they're matching the springs to your cam...
Personally - and just my opinion - I was happy with the CompCams trunion bearing replacement. There's been a lot of talk about a few failures, but from what I've seen a) they were all really big cams and b) the indication from the failure was that the bushings were pressed in incorrectly. I took a fair bit of heat for that analysis, but CompCams and my two machine shops agreed.
Again, don't want to get back into that can of worms I'm sure the bushings are dead silent and will last a long time.
But, frankly, I think just the maintenance over the next year or so (clutch w/slave upgrade, leaky butt, etc.) will keep me busy
But this project is done
