Panel Bonding adhesive/filler
I have a 77 and am looking to bond the SMC(?) inner wheel liners to the inside of the new fiberglass (Vanacor) 1-pc Front clip. Also, eventually I'll need to bond the clip to the body itself.
Any thoughts on a good bonding adhesive? I will probably need something like a qt/gallon of bondo to build up and take-up all the gaps between the panels. They do not "net-out" to good along the flanges...
http://www.evercoat.com/productDetail.aspx?pID=179
This stuff is great. A little pricey, but well worth it. It uses a standard caulking gun to dispense it and comes with a couple of mixing tips. Work fast though, it starts to cure in 5 minutes. Full cure in 3 hours.
Former Vendor
Remember that you are dealing with STRUCTURAL. And the product needs to be able to provide you with the adhesion/strength for that...along with enough work time to allow you to get parts fitted.
"DUB"
"DUB"
Medium Urethane Adhesive
MAXIM™ Medium Urethane Adhesive is a urethane repair material that provides incredible strength and sandability. Best used when a longer open time is required to complete the repair. This material is used for non-structural repairs on all plastics, fiberglass, and SMC.
Marty.
Correction-I miss read your reply.
We used only Marine-Tex on my '71. Worked great. From the tech sheet (bolding mine):
"Marine-Tex is a heavy-duty structural epoxy, used to repair aluminum, fiberglass and wooden boats, reinstall loose or stripped fasteners, permanently bond dissimilar metals without galvanic corrosion, and fill gouges in wood, metal and fiberglass, making repaired areas stronger than before."
I went to the paint store today and got 3M8115 rather than Lord F...?? (I forgot) ... I am very comfortable with 3M, but also the 3M was black and the Lord Fusor??? was beige-ish.
..........ANNNND - the paint store loaned me one of those expensive guns to apply it. But just fyi - the gun works for the Lord stuff too.
I have not heard of the "Marine-tex", but wish I had. The 3M 8115 is very strong stuff and will bond smc panels to metal if need be. It's not expensive, but the gun sure is. Go with the "Marine-tex" if you can, because you'll pay more than that for just the applicator gun with the 3M stuff.
In doing some panel replacement on my C2, my vote goes to Lord Fusor 127 EZ.
I had seen some good things mentioned in the CF C2 forum about using Eckler's bonding adhesive so that's what I went with. With things ready to go a bonding strip and fender panel were ground down, the Eckler's bonding adhesive was mixed and applied, clamps to hold the works together, etc. .. .. Now the 'acid test'. . . For whatever reason upon doing a finger 'spread' test of sorts I was able to separate the bonding strip away from the panel it was adhered to. Thinking maybe this was a fluke - maybe not enough catalyst, etc., I ground off the cured adhesive on the bonding strip and panel and started over. Same result. .. ! .. For whatever reason this happened on a second go-round, I don't know. After grinding down the panel to remove bonding adhesive a second time it was now too thin. More glass and resin had to be added to beef it back up.
After checking out forum how-to's and a restoration site I decided to go with the Fusor 127 EZ. This stuff really HOLDS! . . I have total confidence in using it. It can also be used on SMC panels. The 127 EZ is a two-part system that has a work time of roughly 60 minutes - plenty of time to get parts to be bonded 'just so'. Much faster setting adhesive is also available. The Eckler's bonding adhesive was a little too fast for my liking (10-15 minutes). That it didn't hold too good, at least in my experience, didn't bode well.
A special dual push rod gun (similar to a caulking gun) is used to apply the Fusor material. A bit more expense, but.................the Fusor adhesive works really good. Two mixing tubes come with the Fusor adhesive.
