Paint/Body Corvette Materials, Techniques, and How To
How much clear is required for 4 coats.
Old 11-09-2011, 08:59 AM
c66vet
Support Corvetteforum!
c66vet's Avatar
Default How much clear is required for 4 coats.
How much clear is required to put 4 coats of clear over the base coat?
My painter purchased 2 gallons of clear for me and told me that 4 coats of clear requires 1 1/2 gallons of clear coat for my coupe.
Am I being SCAMED here? I thought that less than 2 quarts of clear would be enough for 4 coats of clear.
I paid for all the materials ordered by my painter (best most expensive paint, clear, primers, etc..) and now there is no more clear left to fix a problem on the car.
Old 11-09-2011, 12:03 PM
Spraygun
Spraygun's Avatar
2 gals of any unreduced clear is excessive. How much it will take to do your car depends on several factors.
What clear
% reduction used
Spraygun used
Painting style
The ratio of Clear to hardner/reducer and the VOC of the clear out of the can varies greatly between manufactures. Euro: HS 2-1 both thick products, Fleet: 4-1-2 thinner products. Ie. you have to spray more of a thinner product to get the same film build on your car as a HS ( thicker ) product. With 2 gals of Spies I could spray 3-4 vettes.
SG
Old 11-09-2011, 12:50 PM
c66vet
c66vet's Avatar
SG Thanks.
I used Dupont ChromaPremier 72200S Premium Productive Clear, Dupont ChromaPreimer activator 12305S, and ChromaPremier reducer 12385S.
Mix ratio;
Volume
ChromaPremier Clear 3
Activator 1
Reducer 30%
I believe I was hosed. The clear was $233.00 a gallon.
Old 11-09-2011, 12:59 PM
Spraygun
Spraygun's Avatar
Damn! I've cleared a 45 foot tour bus with not much more.
You had 12 qts of rts clear if your car isn't 37 feet long you should have had extra.
To How much clear is required for 4 coats.
Quick Reply: How much clear is required for 4 coats.
