PPG primer question - did they give me the wrong stuff?
Rather than rattle-can under hood black from Eastwood I'm attempting to use PPG DCU2060 "Flexed'n'Flat" clear. I've read great reviews indicating it's perfect for that proper under hood sheen.
All these parts are steel (or iron) that I'm first blasting in my abrasive cabinet with aluminum oxide or silicon carbide, so they have a nice grippy surface. We're talking about brackets, pulleys, rad supports, air cleaner lids, that sort of thing.
In any event, the paint store gave me PPG Deltron 2K base coat. As a primer they sold me K36. Reading the data sheet, however, it says that "Steel an aluminum substrates must have a two-step metal treatment, wash primer, or epoxy primer coating before applying K36".
I'm not a paint or body guy - but I have the feeling they've steered me in the wrong direction. Should I be using K36 on the bare metal before my base coat, or should I be using an epoxy primer?
If so, any recommendation (preferable PPG to keep it all in one store) on which product to use? I really want a durable finish.
Thanks for any tips! I'm into a quart of primer, base, and clear for close to $400 and don't want to find out this is the wrong combination of products!
- Dave
- Dave
The epoxy primer has better corrosion protection. It's also thinner which is what you want on brackets, pulleys etc. Thick primer like K36 is meant for blocking. In brackets it is more likely to chip.
K36 has great fill properties that you don't need on brackets etc. PPG has several epoxy sealers that will work well for your application. Unfortunately I no longer use PPG products and can't remember the part numbers.
