Autographed Valve Cover - How to seal/protect?
Hey guys, I went to VIR this weekend, and had the privilege of getting my valve cover autographed by the Corvette Racing drivers as well as the crew chief.
I think it looks great, but I'd like to put a clear coat on the top to protect it. I fully intend to stick it back on my car. I know some folks wouldn't want to do this, but I don't want to hang it on a wall.
Any recommendations on what product and brand of product to use as a clear coat? Anyone done this before?
What did they sign it with????
As for clearing it...you more than likely can clear over it...but depending on when composition of the valve cover...the engine heat and time will more than likely peel off...and if the clear actually bit into the ink of the autograph...when the clear will fly off...so will the autograph.
If the valve cover goes back on...enjoy it for the time you have it. Because it will fail. Not meaning to be a 'Debbie Downer' but it IS the REALITY of it. But don't believe me...I have had to do some things for customers that failed ...even when I TOLD them that it would.
DUB
Best of luck in your choice. Nice piece to have also. It would be like if I had one autographed by Zora...it would go in my trophy case. ADN would care less who saw it. I know I got it...is good enough for me....but that is me.
DUB
The reason I asked is that I've seen tons of other posts elsewhere on the net about how to do this, but they are usually not specific with what products to use. A lot of people apparently do sharpie art on their valve covers and do this all the time...
BUT..painting a plastic part that is in an engine compartment.that has IMPORTANCE...and having it be 'failure-proof" is totally another thing.
And I know that people paint 'this and that' and will 'swear' that it is ALL GOOD and you should do it...But ...like I know...how long does it last. That part is left out...and if it fails...they can wash it of and do it over again and nothing important has been lost.
I know a plastic cleaner is needed to make sure the plastic is clean....and in many cases these cleaners are not solvent based....because they are often used on urethane which does not like solvent interaction when raw and exposed.
I can not help you out any further. My best bit of advice is to call a paint manufacturer tech line and hopefully they would recommend products and procedures in their line that will give you a lasting result...and MAKE SURE you tell them what it is you are trying to do.
Just remember...that the prep is the most important part.
DUB
