Paint/Body Corvette Materials, Techniques, and How To
hole in my floor
Old 09-19-2014, 12:38 AM
Charles.rogers1
Charles.rogers1's Avatar
Default hole in my floor
I have a 1996 corvette and there is a hole in my floor right where the footwell ends (I can feel the carpet through the hole), like someone put a jackstand through it or something, my question is, it looks like it is made up of all fiberglass? am I wrong on this? and if it is couldn't I just clean the area out and sand it down and re fiberglass and resin it back solid? Or do I need to take it somewhere and have a floor welded in?
Thanks,
Charles R
Old 09-19-2014, 05:23 PM
DUB
DUB's Avatar
Received 2,713 Likes on 2,321 Posts
You can laminate it but you CAN NOT or SHOULD NOT use POLYESTER fiberglass resin...you need to use an EPOXY resin...such as WEST SYSTEMS epoxy resin. You can obviously use fiberglass mat.
I would clean it CAREFULLY and DO NOT use water. I would mask it off from the under side and go in on the inside and prep it with a grinder and do all of my repairs on the inside
SO YES,,,the seat needs to come out so your carpet can be pulled out..
But it is your car...do as you wish.
DUB
Old 09-25-2014, 09:21 PM
Charles.rogers1
how would I go about cleaning it? I can get some pictures of the problem soon!
Old 09-26-2014, 06:29 PM
DUB
DUB's Avatar
GOOD Photos help.
DUB
Old 09-27-2014, 12:17 AM
Charles.rogers1
Hard to grab some good pictures cause the car is low and I could hardly get my phone underthere to get some but this is what I could get...
[IMG]http://i62.tinypic.com/jqnloo.jpg[/IMG
Charles.rogers1
Old 09-27-2014, 05:32 PM
DUB
DUB's Avatar
PLEASE take the time to get the car up in the air so you can give me the true picture of ALL of the damage you have.
I can not see how this is the right side ...it looks more like the front outer corner of the left side.
DUB
Old 09-27-2014, 10:23 PM
Charles.rogers1
you are exactly right on the location, that is what I believed to be the corner of the footwell, am I wrong?
Old 09-28-2014, 05:51 PM
DUB
DUB's Avatar
It is the corner of your foot well....BUT I need good photo's. I need to see what you see...so several may be required.
DUB
To hole in my floor
Quick Reply: hole in my floor
