Sanding question
Sanding question
Please excuse my ignorance here...
I purchased a replacement OEM front bumper for my white FRC but the its red. I would like to do all or most of the sanding myself to remove ALL of the red paint before taking it to a paint shop.
What grit sand paper should I use ?
Thanks for the help !
You are embarking on a task that will make you wish you bought a NEW front bumper cover. I know that I would not even begin to do it...and I do body and paint work. The reason being is that it is so easy to break through the factory primer down to the raw urethane...which can and usually does change the process of how it need to be prepped and primed prior to paint.
Having the bumper stripped with a media can also damage the surface...due to the materials that GM uses really bite really well into the urethane.
I wish you would have asked what to do prior to buying this used bumper cover. Not saying that you can not do it....but it will take a lot of time and precision sanding...and I mean A LOT OF TIME....only because I have done this BEFORE and refuse to do it again...unless the owner is will to pay for my time...which they will regret doing by the time all the smoke clears and I hit them with the bill.
You have to be careful in what grit because an aggressive grit will make it really hard on the body shop. I would use 500 grit wet. The only reason being me trying to tell you to use another grit that is coarser...you would have to know when to stop...so the 500 grit wet can remove those sand scratches.
DUB
DUB
I just want to do enough sanding to get as much of the red off as possible.
And it's the oem read paint.
Do not be surprised if you sand off your finger prints and your tips of your fingers bleed...if not others areas of your hands.
Just be patient and stay focused.
DUB
DUB
