Small Under the clear coat paint imperfections
Hello, I have a 95 polo green C4, I have these what appear to be small bubbles under the clear coat on the edges of the quarters and front of the door, edges of targa, and bottoms of B pillars . They are VERY tricky to see unless under the right light. There is no indications to me that the car has been repainted I looked at it top and bottom and counldnt find a single tape line or overspray, although I know what to look for I am no means an expert. The only other things I saw were inside the door jambs there was some paint chipping down top bare white, which looks like from dirt being ground into it from the door opening and closing (it was a bit cruddy inside the door jamb) I read high and low that this could be the signs of a good repaint gone bad, or the car sat under a cover for a long period of time and caused a moisture problem in those areas. I am inclined the think its the latter, based on the vehicle history it was not driven for a few years. I dont want to start opening a can of worms with this, but what would be the worst case scenerio? Should I be worried about it popping up and giving me a polka dot corvette, or just leave well enough alone give it a good buff with my DA polisher and call it a day?
Worst case scenario----- A repaint.
Taking a polisher to it is pointless. You can do more damage that good. And the damage done can be removing much needed clear cost thickness....which aids in keeping eh clear thick enough to fight against the UV's of the sun. If the clear gets too thin...the clear chalks out and that is the beginning of the end of the paint job.
I agree...that the car was subjected to moisture being trapped. This is why I HATE car covers...and if one is used...it required maintenance to keep the paint and body in good condition. It is not just cover it up and forget about it.
It more than likely will pop in time...so I would say...ENJOY the car and do not worry about it until it gets bad enough to do something about it....or if this is an issue that you can not live with...then paint it again.
Obviously...it is what you want.
DUB
DUB
DUB
DUB
Update: I went out this morning and it was VERY cold, the paint imperfections looked more pronounced. When I went to look at the car it was warm and I didnt really see them. Are these kinds of things weather sensitive? It will be sitting outside all winter, because I live in a complex with no garage, and I dont want it to make it worse. Getting a little worried...
The polisher I have is a meguiars DA polisher. The pad is SUPER soft and plush and made for waxing and polishing. It is non agressive and the polish and wax I use is nothing more than polishing oils, no abrasives.
Doing your polishing is your choice and I am NOT telling you not to do so. Hopefully it comes out as you desire.
DUB
