1976 Urethane front bumper cover
1 Post
Dub et al
Here are pictures of how the Ecklers cover is coming out. Any and all feedback is welcome.
Quite of bit of sanding, fitting, sanding but I don't want to take to much..
LOOKING GOOD...Then it will be how does it look after it has been primed and test fitted again.
DUB
DUB
There way is NOT correct....because how are you going to get paint on the flange that is NOW touching the body???? AND...you will either have a sharp tape edge...or paint 'bridging' the gap or seam.....EITHER WAY...a TOTAL FUSTER CLUCK!!!! And what about the primer that is needed so the paint will stick.
And to add to that...IF 'they' think that their way is the correct way of doing it...I would SERIOUSLY WONDER if 'they' are going to follow proper procedures to primer it and then use the CORRECT elastrometric additive to make sure the paint remains flexible.
Can it be done 'their way'...YES...and I can also brush house paint on it also if that is what you want. They have gotten into 'bad habits'...more than likely doing so much insurance collision work...'they have lost touch with reality....and chose the path that is the easiest.
DUB
You lost me. The first part I get.....but the 'spray test fit spray'....what do you mean????
DUB
1 Post
Sorry...
Is this a case where I can just drop the covers off and have them sprayed or do they need the car?
I am new to the body work side of this so thanks for being patient.
SO....depending on the shop you take it too...and how close you want the color...and how many attempts they have in tinting the formula to get the best color match...is up to you and the $$$.
DUB
All depends if you can live with the fit of the bumper you have now.
IF you plan on installing a rigid fiberglass bumper...which I often do....it really does not mater who you buy it from because it is the 'luck of the draw'. You can get one bumper with a twist in it and then the next one be perfect...and that perfect one may have air pockets UNDER the gelcoat in the sharp corners.
I prefer rigid fiberglass bumpers. Urethane is obviously faster....but I can dial in and fit a fiberglass bumper and get it looking really sweet. But it does take some time. AND in you case...with the front clip being painted...it would be EXTREMELY hard to accomplish without damaging the paint on the front clip.
DUB
1 Post
The bumpers are pretty dialed in and I found a shop not far from me who specialize in restoration. A great guy who knows a ton (thanks to you I knew what questions to ask). Remove bumpers try like hell to get the match as close as possible .. Remount. See how it looks..
Roll the dice but I think she should be all set cme spring!
Thank you again Dub!
I HONESTLY hope it turns out very well for you.
DUB
Looks really good in the photo. BUT...that really does not matter what I think or anyone else....it is your car and if you are happy with it....that is ALL that matters.
Check that repair off your 'list'.
DUB
DUB
