Paint/Body Corvette Materials, Techniques, and How To
Picture needed of tunnel
Old 01-19-2015, 10:21 PM
PierreOlivier
Support Corvetteforum!
PierreOlivier's Avatar
Default Picture needed of tunnel
Can someone post a picture of the tunnel for a 1965 convertible with power windows. I think the hole I have is another bubba .
Here is the picture of mine with the repair I have done so far for the hole next to the shifter.
Old 01-20-2015, 09:31 AM
egnuol
egnuol's Avatar
This is my '65 convertible with the console bracket still in place.
Darrel
Old 01-20-2015, 10:40 AM
PierreOlivier
Darrel
Thanks Darrell. I am assuming that having power windows doesn't make any difference
Old 01-20-2015, 11:46 AM
egnuol
egnuol's Avatar
Pierre,
The harness for the power windows should be above the floor panel. I'm not sure why they cut a hole there. Mine has crank, sorry, I can't help much.
Darrel
Old 01-20-2015, 12:26 PM
egnuol
egnuol's Avatar
Pierre,
Darrel
After checking in the assembly manual( which should have been first), it does show a 3.09"x1.69" hole and a pocket shield for the power window switches. Yours was a retrofit maybe ?
Darrel
Old 01-20-2015, 06:08 PM
DUB
DUB's Avatar
Received 2,713 Likes on 2,321 Posts
Darrel
NO...his is a NON-power window car.
The math is quite simple to figure out....and if the hole is shown in the manual...then a hole is needed along with the rubber boot to keep air from blowing in and effecting the switch connections.
If the boot is not available...there are numerous ways to get around it unless you are going for PERFECT.
DUB
Old 01-20-2015, 11:29 PM
PierreOlivier
DUB
I am going to order the boot (around $25) and then make sure the hole is lined up right and snug. Here are the pages from the AIM which doesn't seem to show any hole.
Old 01-21-2015, 08:59 AM
egnuol
egnuol's Avatar
Check in the BODY section under A) cowl, dash and door frame. A-31 page #2
Titled -- Window Electrical Control-Contents
Old 01-21-2015, 09:13 AM
egnuol
egnuol's Avatar
Here is the sheet.
Darrel
Old 01-22-2015, 12:56 AM
PierreOlivier
Here is the sheet.
Darrel
Thanks Darrel. I found it when you pointed it out before.
The clips for the two screws to go into are still there. I just need to get the cup and screws and make sure that it is "snug".
Old 01-22-2015, 03:07 PM
egnuol
egnuol's Avatar
You are welcome. Good luck and get some sleep.
To Picture needed of tunnel
Quick Reply: Picture needed of tunnel
