PCL primer
PCL primer
Does anyone use PCL primer 901?
POLYPRIMER
HIGH PERFORMANCE
HI-FILL POLYESTER PRIMER SURFACER
VOC: 200 g/l or less, 1.66 lb/gl
Curious how it stacks up to Slick Sand, K36, or others.
Thanks.
POLYPRIMER
HIGH PERFORMANCE
Thanks.
I don't...but that does not matter. AS long as your fluid tip is large enough...and you do a test by spraying something you do not care about to get a feel for it. You should NOT have any problems beacsue ...it being a polyester primer....when activated withe the MEKP...it will fill and harden well.
K36 is not in the same league...a completely different type of primer all together.
DUB
DUB
