What Sealant Do I Use?
For the door jamb ....SEM BEIGE SEAM SEALER ( part number 39477) and takes special gun to apply. And I know you did not ask but this jamb is not ready for seam sealer. The bare metal showing is not good. Knowing you did not ask but this reply is for others who may look at your photos. I would strip all the paint off the steel portion of the hinge post and then apply a coat of PPG black epoxy primer. When it has dried. THEN I would apply the SEM Beige seam sealer.
AS for the black stuff in the wiper cowl. I clean the cowl out and then apply the same seam sealer and ten apply some PPG black epoxy primer and then apply a coat or two of black paint on that to seal it all in. I clean and do whatever I need to around the wiper arms and get them sealed again also. All depends on what the customer is wanting. if they are wanting it to look like the crappy job GM did. I use products from C.R Laurence for that.
DUB
DUB
