'79 Exterior Black Trim
I need to retouch the semi-gloss trim on the trim around the windshield and rear glass on my '79.
Searched here and found contradicting information one of which agrees with my experience with similar on my '99 Seville.
Contradictions: Use Krylon semi-gloss black. No--not Krylon--use SEM black trim paint. Essentially nothing sticks as it's stainless steel and it's a special baked-on enamel.
My experience: Similar to the last--despite very careful prep and painting the entire driver door pillar trim on my STS (gloss Krylon that I rubbed down to a perfectly matching sheen) the paint did not stick to the offending (bare) spots along the edge.
Any suggestions are greatly appreciated!
Looking for a ONE TIME product is basically NOT going to happen in my opinion. GM had the best products and they fail in years to come.
I have a special primer that I use on polished stainless steel....and it works...but it is no longer available. SO...trying to get a good etch in the molding by media blasting and a primer that will also etch so the paint will adhere is what is needed...obviously.
I honestly thought of taking the time and see if I can shrink wrap them in a semi-gloss black vinyl.
DUB
DUB
Thank you DUB for confirming my suspicion. I'll just carefully brush in some paint. I know it won't last for long and it won't be perfect but it will certainly look better than the glaring bright among the black and Corvette Green.
I decided to attempt a nice repair so:
1) Masked
2) Thoroughly cleaned with lacquer thinner
3) Carefully spot sanded the bare sections
4) "Primed" with mar-hyde "Black Satin" Automotive Trim Coating--about 3 light coats within one hour.
5) Finished with Dupli-Color "Ebony Black"--about 3 light coats within one hour.
6) Two coats of wax after two days
Result looks very good and has been in one rain storm (intentional) but I have no idea if it will last.
1) Masked
Looks good.
DUB
DUB
Thanks. I just hope it lasts for a while.
Strange how the metallic "Corvette Green" came out blue in those photos. I took some shortly after I got the car (same nice Nikon SLR) and it definitely looked green on the same computer screen.
Then I did some serious (almost all hand) polishing with my Wolfgang products to hear the neighbor lady across the street ask me, "Did you repaint the car a different color?" and a friend asked, "Did you put on a new clear coat?" My answer to both was, "No, and I'm almost certain that it's mainly the original 1979 lacquer."
I HOPE your trim lasts a long time. They are really FUN to get right and last....and heck....GM had used some awesome stuff on them and they still failed over time. Sometimes ...some 'things' are just what they are....a part that will require maintenance and repainting.
DUB
