More repairs😳
Hi DUB,
No please , i understand where you are coming from and your concerns, very valid indeed . The primer can be removed although it is called a self etch primer .The main aim for putting the primer on was to prevent the frame from getting surface rust again .
What type of paint would you recommend i use on the windshield frame so i do not encounter issues with the bonding of the glass to the frame?
Cheers for now ,
John
Cheers for now ,
John
AS for the surface where the urethane will be applied so the windshield can be bonded in place. I do nothing at all. If it is bare steel...I leave it so the glass company can apply their special primer and put the windshield in. IF for some reason I need to apply a primer...I apply PPG epoxy primer ...but I do not put it on THICK.. I just get coverage and stop....so the glass company can prep it and apply their primer to it.
DUB
