spot gelcoat possible?
I need to fix this old repair (previous owner did). After I fix this fender and the seam can I gel coat just this fender for now and gel coat sections as I get them done or do I have to shoot the entire car at once.
I honestly do not think that you can gelcoat it. I do not think that this Corvette has the press-molded panels..and are rather the SMC design that came later.
What year is the car? I can not go off of screen names.
And I really need to see a photo of the panel prepped all the way down...so I can see what the panel looks like....but from what I can 'try' to pick up on...this panel is NOT the early press-molded panels....but it is hard to tell...because I can ALMOST convince myself that I can see the fiber structure in your first photo in the gash. BUT I can not confirm this.
DUB
DUB
Light gray color that can have a marble effect is what we will call SMC....where you might see dark gray streaks in the panel.
A dark panel...almost back in color where you can see a swirling structure of the actual fibers of the fiberglass is the pres-molded polyester panels.
DUB
