1974 T-Top Paint Prep
1974 T Top Prepping for paint
Just removed stainless trim and weatherstripping, patienience is key to process. Have a few questions:
1. What is the black tar like sealant? Is it available? Is there a better substitute?
2. The rivets I drilled out (4 om window side of each top) rattle. Any tips on how to remove?
3. I count 20 holes and plastic tees, Why do vendors show 18 or 19 hole weatherstrip? Can I reuse the plastic tees?
4. I will be replacing all weatherstrip, any recommendations on what weatherstrip material to use? Is new stuff better than original latex?
5. Are the tool sets worth it ? seems like my putty knives will work.
6. Any preference on black or yellow glue?
7. In photo 2 shows a piece of foam tape is that available?
8. How long should I wait after painting before applying new weatherstrip? It will be cold in Md soon, should be painted in ~ 2 weeks. Door weatherstrip needed to drive home. I can wait on other stuff.
thanks in advance for comments
Bg
Bg
Do not know what you mean about 'tool sets'????
Some like the yellow...some like the black. Whatever you want...unless you are worried about any judging.
I can not see what you are talking about. If it is between the weatherstrips tack where it attaches to the other stainless trim...you can use 'truck bed camper seal' and cut what you need or go to a home improvement store and see what they ahve. It is NOT specific to this area...it is only a foam tape. Closed cell preferably.
DUB
Thanks Dub,
Your answers give what I need to march on. Thanks for sharing your expertise and taking the time to respond.
I have found that the prep process is far more complex and time consuming that I anticipated. I now have a full understanding of the effort and costs associated with a legit paint job.
bg
bg
KEEP THIS IN MIND!!!!!
IF you are going to prime the T-tops very well...seal them....then apply a basecoat and clearcoat to them....
When you go and TRY to re-install the stainless trim at the front.....this added material you have applied to the T-top....can POSSIBLY cause for you to have a problem getting the trim to slide back on and NOT peel back clear....OR....cause the clear to bubble up at the edge of this trim when it gets hot and is curing out in the future.
Just 'saying'...because this has BIT me before....and I have a way to greatly increase my odds so I can get the trim on without peeling back clear and NOT have the clear bubble out from under the trim in time. Just make sure the T-top is really dry...which means for me that I use my infra-red heater and bake the paint for days on end. Heat applied and taken away...and repeated countless times.
The sealant that I use is CRL 7708 and/or CRL 1716.
DUB
DUB
Thanks DUB I'll wait on installing the trim & maybe test fit without forcing it. Also you can add clairvoyance to your many talents, as I had no clue what sealant to use. Planned to research it later, thanks for saving me the time / effort.
bg
bg
No...I simply read and comprehended what you wrote in your first question on this thread. I just came back with the part numbers because I did not have them at home when I responded initially.
You will more than likely need to spread the trim further apart so it is not so tight. that is what I do. I use a 'somewhat' common tool for it. If you stop and think about it...you more than likely have it in your tool box.
DUB
DUB
DUB,
Just read Rebuck33 post and it puts all this stuff on the back shelf. Prayers and best wishes for Rebuck33 & daughter.
That said I was up all night thinking about my tool box, I have some big screw drivers that might fit the bill, but I also have some wooden wedges and when forced in the trim they feel pretty nice, (wedge made from 2"x8" PT pine). I plan to measure the top and the trim gap and then cut a wedge to fit. If possible I will wait for clear to go rock hard before putting the tops back together (I cant think of a reason why I cant wait).
I removed the weatherstrip from doors and they still shut nice. Think I can get away with driving home form paint shop (~ 20 miles) with out strip in doors?
Note just received weatherstrip (Willcox) came with plastic tees installed.
bg
bg
DUB,
bg
bg
I know many people who need a 'reality check' and walk the halls of a hospital...because they are so caught up in trivial crap that actually means nothing at all when you get right down to it.
SENT you a PM.
YES...you can drive it with no weatherstrip on the doors. No damage should occur if the door is set correctly and NOT allows to go to far inwards when the door is being shut.
DUB
