C7 front splitter paint damage
I painted my C7 front splitter with automotive vinyl paint made for urethane. I must have hit something and now the paint has flacked off at the point of impact. Painting was a mistake. What do I use to remove all the paint and leave the urethane looking natural (black)? A new splitter is $100.
The black might not be the splitters natural color but the color of a primer. If your splitter didnt come presprayed with a primer, it may be the reason why your paint chipped or its the type of paint you used. I sprayed painted my whole front bumper on my daily with the right products and that thing is gonna last for years.
These are the layers of a cars body part:
1.Urethane or whatever type the plastic is.
2.Layer of primer for the base coat.
3.Base coat color.
4.Clear top coat.
I believe body shops uses a paint stripper which they spread out over a body part and you have to scrape everything off.
You can call a body shop and ask them what they do or just stop by with your piece and ask them what they do. Im sure they would help you out.
3.Base coat color.
4.Clear top coat.
Not knowing what you did to the part PRIOR to shooting on it what you shot on it ALSO makes it hard to tell you what to do.
Not knowing the urethane part was raw or primed...before you shot it also make sit hard to tell you.
There are chemical strippers for urethane but they can cause the urethane to swell and it may take few days for this effect to go away...but not knowing what you are wanting or expecting...that again...is hard to tell you to do that.
Without photo's...it is hard to tell you to just go in with wet sand paper and sand it off....or even take an air hose and blower and blow the stuff off...because if it flaked off....then it did not stick and it might blow off with high air pressure.
DUB
Thanks to all. I used a single stage paint with a hardener from NAPA. Before painting I sprayed a flexible grey primer from a can. Bad parking on my part. Paint stripper, acetone - methylene chloride type, is tough on plastic so I may just get a new splitter and fix this one shown later.
