62 stripped to bare fiberglass question
working on a 62 c1 and it was dry stripped to the fiberglass and looks to be a good job, body has been rough sanded with 180 to get a good mechanical grip for the primer ,key stress cracks repaired ,, any recommendations on a spray on polyester filler primer for the corvette fiberglass prep ,, thanks in advance gmonde
dariopop (01-29-2016)
Running a truck/bus body shop...you deal with fiberglass/SMC panels.. I am sure your paint jobber should have something to choose from....I hope.
BUT...Many thoughts and views on this subject.
I prefer to apply a gelcoat on a car like this.
Some feel that other products satisfy their needs.
I do not use this specific type..... but Slicksand is a worthy polyester primer. There are many made from some paint manufacturers....so...it depends on what you can get your hands on.
DUB
DUB
yes we work on a lot truck hoods, fiberglass bus panels mostly 5-10 year old stuff but they are not 50 year old body's and have the texture that this does ,,I have a gallon of feather fill g2 that I an going do some experimenting with before we go live ,, we will see
gmonde
gmonde
gmonde
gmonde
DUB
DUB[/QUOTE]
FWIW, . I used both on my projects. But I'd stay away from Eckler Gelcoat whereby a wax layer rises to the surface. Evercoat
Gelcoat cures with a PVA layer that you spray on and comes off easily the next day with soap and water. My .02
DUB[/QUOTE]
