Where did my gap go.
Painted the rear part of my 67 GTO. Had all the gaps perfect. After spraying the gap by the rear windshield is now real tight. How can I straighten this out.
And a very good description on how it was primed/painted and that process would be GREAT so it will turn over more pieces of the 'Jeopardy' puzzle.
BECAUSE if gaps are set TIGHT without taking into considerations the film build of primer and paint and clear. These products will obviously add to the panel..and thus can cause for 'things' to close in on themselves. And not knowing anything on what was done.,..I can only throw stuff out there and hope it sticks.
DUB
I know where the gap went, it got filled in by paint. What is the best solution, watersand around the gap with 1000 grit until it is back to where it was. I don't want to bust thru the clear and have to repaint the edge.
WELL...I GUESS you need to do just that. If the PAINT is too thick and you KNOW that what the problem is....then you have to do what you have to do and 'chalk it up' to a learning experience.
And if you have to paint it again due breaking though...well...welcome to my world where I have done that in the past.
I can only comment on what you are writing due to not seeing what you have going on.
DUB
DUB
