body work basics
body work basics
ok, so I started on the seams. ground them out and started a small test spot with VPA. tried to work it down and ended up flattening out a spot (where I am pointing). tried to use guide coat but not sure how to form curves. seems to me I should shoot a couple of coats of primer and work the seam until i remove the primer and that will tell me to stop before damaging the panel. can I use VPA over primer?
If you need help in how to do body work and sanding techniques...PM me so I can get you my number if you do not have it already and we can talk.
If you choose to learn on your own...which you can if you choose...get ready to use a lot of VPA until you figure it out. Because it is NOT only knowing how to spread the VPA...and sand it...but also acquire the sense of 'feel'. The sense of 'feel' is the MOST important part.
You might be surprised on how much you can gain from a simple phone call.
DUB
