Paint/Body Corvette Materials, Techniques, and How To
Metallic or non Metallis Paint
Old 09-04-2016, 10:22 PM
8valve
Support Corvetteforum!
8valve's Avatar
Default Metallic or non Metallis Paint
I have a 74 in Silver Mist, Paint code 14L. Due to lots of chips, I have decided to repaint. I dont see and metallic particles in the present paint ?
I have shot many trucks and cars that I have built, but never using Metallic Colors. If 14L is metallic color, can anyone offer any special tips on shooting metallic
Thank You
8Valve
Old 09-05-2016, 05:12 PM
DUB
DUB's Avatar
Received 2,713 Likes on 2,321 Posts
Holy smokes.....'special tips'...yeah..I have numerous...so many that I can not take the time to type them out.
A lot has to do with the paint you are using...because NOT every paint company has the same characteristics.
Unless someone 'chimes in' and types out a list of 'tips' that you are satisfied with...PM me and I will get you my shop phone number and I would be GLAD to talk to you instead of typing for a long, long time.
DUB
Old 09-05-2016, 07:18 PM
8valve
8valve's Avatar
Thank You DUB, PM Sent
8Valve
DUB
Old 09-06-2016, 04:40 PM
mark79,80
mark79,80's Avatar
When I painted my 1980 silver Corvette in the original color, using PPG DBC Base coat I sprayed the last coat as a drop coat. The clear was PPG DCU 2002. The finish turned out very uniform with no mottling of the metallic particles. I am not a professional, so would be interested in DUB's and any other professional's techniques.
Old 09-06-2016, 06:13 PM
DUB
DUB's Avatar
I will touch on this one technique.
YEP....it has been a really long time since I painted with PPG paints.
In the paint system I use I pretty much do the same thing as when the last coat goes on..I go right back over it to get the metallics laid out as I want them....and due to the properties of the paint I use. The paint does not leave overspray dusts that collect on the panels due to teh reducer I use is slower for the current temperatures I am shooting at....so everything basically 'melts in'.
I do remember back in the day...the PPG paint I was using ..I always had to fight it. And this was WAY before GLOBAL or any new stuff came out. I was using DBU and DBC back then....due to that was basically it....otehr than lacquer (DDL)
DUB
To Metallic or non Metallis Paint
Quick Reply: Metallic or non Metallis Paint
