Paint/Body Corvette Materials, Techniques, and How To
Clearcoat application was going well then Murphy stopped by!
Old 09-22-2016, 06:40 PM
TWINRAY
TWINRAY's Avatar
Default Clearcoat application was going well then Murphy stopped by!
My problems are that I don't paint enough and that sometimes in my "booth" you can't see! I laid it on too heavy on the passenger door. Should have speeded it up on the vertical surface and didn't see it soon enough. Then some rusted metal flakes dropped unto the middle on the hardtop and got embedded into the clear. I picked them out and don't know if it's spot repairable or if the roof needs to be redone. Other than that it seems OK cept for a few bugs that decided to commit themselves in the clearcoat.
Old 09-22-2016, 07:43 PM
Dave Tracy
Dave Tracy's Avatar
It all can be fixed.
Old 09-22-2016, 08:20 PM
TWINRAY
TWINRAY's Avatar
Thanks Dave, I needed that
Like I said, Layin' on the clear
I do this for my own amusement. There isn't enough money for me to do this for someone else.
Old 09-22-2016, 08:34 PM
TWINRAY
TWINRAY's Avatar
The "booth" where I had problems with the hardtop
Old 09-22-2016, 08:38 PM
TWINRAY
TWINRAY's Avatar
All good here
Old 09-23-2016, 05:53 PM
DUB
DUB's Avatar
Received 2,713 Likes on 2,321 Posts
I can clearly see why you had problems with the hard top.
It is being supported too close to the ground and needs to be high up like the hood and rear deck....if that was actually where it was when you clear coated it.
It can all be fixed...like previously mentioned.
DUB
Old 09-23-2016, 06:56 PM
TWINRAY
TWINRAY's Avatar
DUB
Yeah, thanks DUB.
I had to manouver those pieces by myself. I should have positioned the HT higher. I'm going to try and spot repair it. If that don't work, I'll do it over. Thanks
Old 09-24-2016, 05:27 PM
DUB
DUB's Avatar
I learned a long time ago not to set parts upon buckets and such that are close to the floor. Even in my paint booth...the air from the gun stirs up stuff that is on the floor and gets into parts. I then began the practice to make sure they are up high.
You should be ok in going your repair. Just have it in your paint area and have it high up....I am sure you will get it.
DUB
Old 09-26-2016, 06:28 PM
TWINRAY
TWINRAY's Avatar
DUB
I would have liked the hardtop placed higher but I was hoisting around myself and thought it would be OK on a couple of big boxes but that wasn't the case. What i should have done is do it at another time when I could place it where I could see what I was doing. You can't paint when you can't see. I'll now probably have to redo the whole top over.
Old 09-30-2016, 08:58 PM
bazza77
bazza77's Avatar
Beautiful colour
Old 10-01-2016, 07:06 PM
ILLUSHN
ILLUSHN's Avatar
I also love the color. Looking forward to the finished product.
Old 10-01-2016, 09:50 PM
Dt86
Dt86's Avatar
Me too!
Old 10-02-2016, 01:15 PM
TWINRAY
TWINRAY's Avatar
Thanks, fixed the runs but awaiting for rain to stop so I can redo the hardtop. Will start colorsanding when I can get it outside and use a hose with running water.
Old 10-02-2016, 01:42 PM
Dt86
Dt86's Avatar
Knocking down the orange peel is fun. Doing that right now. Just came in from the garage for a break actually lol. Looking great!
Old 10-14-2016, 03:29 PM
TWINRAY
TWINRAY's Avatar
DUB
I redid the top. Sanded with #220, 3 coats epoxy primer, blocked flat with #400 then #600, base + 5 coats of clear. Will probably need to block out 2 coats to flatten. Slight sag on one side flat and hose hit the other side flat. That's why I did the 5 coats. On another note, pulled my back out when I took hardtop off these horses without help to move it inside for the night. Guess I forgot I'm not 20 YO anymore.
Old 10-14-2016, 03:35 PM
Dt86
Dt86's Avatar
Looks great! Hope your back is feeling better soon. If you were closer I'd be happy to lend a hand. I know time is of the essence with the dropping temps.
Old 10-14-2016, 05:39 PM
DUB
DUB's Avatar
LOOKS GOOD!
QUESTION: If it was already painted and cleared...and seemed to only have trash/debris issues......why did you epoxy it again??? And then shoot it all over again.
Just curious.
DUB
To Clearcoat application was going well then Murphy stopped by!
Old 10-14-2016, 08:07 PM
TWINRAY
TWINRAY's Avatar
Thanks, all good. Temp not a factor now that painting is done. Back is a problem in that yesterday only able to spend 1 hr and today 2 hours on colorsanding. I go slow so will probably need another 8-10 hours ( at least) on colorsanding as i'm not even done with #1000. Ibuprofen every 4 hours is now the name of the game. It's a herniated disk, happened before.
Old 10-14-2016, 08:17 PM
TWINRAY
TWINRAY's Avatar
LOOKS GOOD!
QUESTION: If it was already painted and cleared...and seemed to only ahve trash/debris issues......why did you epoxy it again??? And then shoot it all over again.
Just curious.
DUB
I had to sand 3 spots feathered down to the Gelcoat I sprayed on. I know I could have spot epoxyed those spots and applyed base but decided to start with a fresh slate . Also figured the newly sprayed base would better adhere all over to the newly sprayed epoxy plus I wouldn't have to worry about blending. I don't like the idea of all that product on but it is, what it is. If this didn't work out, I would wait till next year and strip all off what I put on and then start over.
Old 10-15-2016, 05:44 PM
DUB
DUB's Avatar
THANK YOU for the reply!
I truly hope all goes well and it lasts and lasts. I am not so worried about all of the amount of material on the hard top as much as I am the possible 'ring-out' effect that can show up later.
DUB
Quick Reply: Clearcoat application was going well then Murphy stopped by!
