Full bolt-on ZO6 times?
What type of times are full bolt-on ZO6's running in the 1/4?
Full bolt-ons being, no internal work, just the bolt-ons that
get the newer Z's into the ~390-400rwhp range.
I'd like to see how fast a bolt on ZO6 is with drag radials or
slicks actually. I know people have gone 11.9's in stock ZO6's
so I'm guessing at least mid 11's for bolt on ZO6's with sticky
tires?
tires?
1 Post
St. Jude Donor '05-'06
With a few bolts on my 01, see sig, I got down to 11.89 so far, 1st time out with LTS and a good tune. I do not drive very well, and my launches are not huge either, and IMO, and reading many threads, low 11 with intake, headers, tune, et streets, gears, and a very good driver, is with in reach. Hell I am just to see 11s!
Dave
Dave
Originally Posted by Insom
wow so close to 10's on a stock cam.. thats amazing seeing the cam only record is a 10.9 isn't it?
Paul ran a 10.37 with 385rwhp with bolt ons. Still a very large gap between 10.86 and 11.37.
Brent also ran a 10.96 with only 397rwhp(cam only).
Both records will be broken IMO.
Originally Posted by robz
The cam only record is 10.86 R White. I believe the highest trap speed is 126.7 mph. I'm confident 10.7x's will happen cam only!
Paul ran a 11.37 with 385rwhp with bolt ons. Still a very large gap between 10.86 and 11.37.
I mainly asked because a few people have said the new ZO6 will not
go 10's with bolt-ons. I replied with the fact that a current stock ZO6
has gone high 11's, rare but it's been done.
Seems that if a bolt on C5 ZO6 can go low 11's, high 10's from a bolt-on
C6 ZO6 should be a friggin cake walk.
60'...1.616
1/4... 11.405
MPH...123.61
Is LS1Tech the only place with a list of records, for stock internal Corvettes?
That's impressive with 385rwhp since I know bolt on ZO6's have touched 400rwhp internally stock.
Originally Posted by Qksilver
My Best: (Vararam, SpecIII, Air bridge, Nitto DRs & B&M shifter)
60'...1.616
1/4... 11.405
MPH...123.61
60'...1.616
1/4... 11.405
MPH...123.61
Put yourself down on the list on that forum for now!
Location: Make it 3 yards motherf**ker and we'll have us an automobile race.
I've run 11.25 @ 123.7 with bolt-ons and there was more left in it. The DA was around -200 that day. I'm an old school hot rodder so my bolt-ons aren't the same as "LS1" bolt-ons. I installed Comp Cams 918 springs and roller rockers because I was installing a supercharger a little later. All of my mods were done with the supercharger in mind , so I went a different route than someone who wanted to make a fast bolt-on car. For the record , my car made 383 rwhp and 369 rwtq before that run. There's no doubt in my mind that if someone wanted to , they could run 10's with bolt-ons. Unfortunately , making a "fastest bolt-on car" doesn't seem to be a priority with Vette owners
A bolt on Z06 can go low 11's. High tens would be very tough with the current bolt ons available now, but anythings possible.(especially since it was done with 397rwhp) You might have to strip the car down quite a bit. I understand your point though, I think a bolt on c6 Z06 will be able to run 10's but it still won't be cake. Rim and tire size may play a role in hindering a c6 zo6 in running very low. A 16 inch rim will not fit and hopefully a 17" will. It's all about traction/60'. Obviously you'll need great weather,conditions,etc. I guess we'll see.
