Holding Car at Starting Line Brake Questions!
Isn't that one of the problems you were having...after xxx passes the pedal was softer and you were pushing through.
Cruise-In VII Veteran
I don't know if it gives you a more firm pedal initially, but my understanding is that it holds up better to the heat and pressure. It should allow you to maintain pressure for a larger number of passes.
