drag wheel backspacing
St. Jude Donor '10
I'm going to have some drag wheels made up, I've taken a few measurements, but before I placed the order I wanted to hear what backspacing other people are running on their C5's (without minitubs)
Great question. However you have to know rim width to determine the minimum back spacing. So what size rim are you going to run? What rims are you using? You know the barrel can not be stamped/tapperd on a C5/C6 due to the ball joint? CCW is the only wheel i've seen with the perfect back spacing. Bogart typically sits a little to far out IMO. Good luck with your wheels though!
St. Jude Donor '10
Looking for a ~11" wheel in 16" dia. Backspacing, unlike offset, should be (for the purposes of cramming in a wide wheel) the same for whatever width since its determined by the inner wheel well. My best guess is that the Bogarts poke because most of them are only available in a maximum of 7.375" backspace which appears to not be quite enough for these cars
There is some room for some slight taper with some grinding on the spindles (you can get some Camaro 16"s up on there with some grinding). I'm going to get all of my measurements together and send them off to Diamond and see if their barrels will clear.
Rim width 11in
_______________
_________Back spacing 8in
_____<offset -Dont matter its determined by back spacing
Thats dimensions I would give and be pretty close. Might need a little more back spacing. I can measure my ccw 16x11 when I get home. Unless you want to buy them?
_______________
St. Jude Donor '10
Rim width 11in
_______________
_______________
I just found your FS thread, I'm becoming tempted, just have to source some front runners. I'll try and price some stuff out and PM you about it this afternoon/evening.
