Supercharger claims
Supercharger claims
I am set up to have the A&A Corvette supercharger installed on our 2002 Coupe. Stock hp is said to be 350 hp. After installation and tune, they said it should be approximately 525 rwhp. If this is true then our coupe should be faster than a stock 505 hp "at the crank" Z06.
Have others found this to be true?
500hp in a big cube NA motor will usually beat a smaller cube power adder car with the same power level. Torque curve will be steeper on the big cube motor.
However, it doesn't take much to move from 500hp to much more in the supercharger car.
You may make more peak power but the power curve and nice long tq curve of a NA 427 shifting @ 7 grand and making big power from idle up is hard to beat, not too mention the weight advantage. But as others said doesnt take much to go above 525.
A C6 Z06 weighs exactly the same as a stock C5Z so there is no weight advantage. The only advantage the C6Z has is powerband. A C5Z with a blower making 525 at the wheels makes 75 more hp at peak than a C6Z. It will be tough but I think the average stock motor, Blown C5Z would take down a C6Z.
C5Z with a blower and traction would have a better shot
Maybe one of these days, I will meet up with a 505 hp Z06 and we can see which one has the advantage. I was told that the coup has better aerodynamics than the Z06, so the top end speed should favor the coup. Off the line, maybe the Z06 would have the advantage. ???
One thought I had is that I hope that with the s/c and tune, that it will pass the tailpipe smog test here in Calif.
A&A has a "CARB" California Air Resource Board certification for all 50 states, but it still has to pass the tailpipe test.
Mine passed the sniffer test with ease. If you get it tuned right, you'll be fine
I am sure you are right... If it is not a stock Z06, my car would be in trouble.
I am just looking for about the same power as a new stock C6 Z06 has. If it is a little faster, then fine. I am happy with the coup styling.
realistically if your 02 coupe is mostly stock and is a 6 speed i would expect 490-500rwhp. so lets talk real here even if a 2002 coupe is 200lbs heavier than a c6zo6 but the zo6 dynos lets say 440rwhp the blown c5 still has 60rwhp. and what with the power curve? there is nothing like a centrifugal supercharger they are designed to make max hp and torque and max rpm meaning the higher you rev the harder it pulls. so in reality if you are a good driver you should be able to beat a bone stock z but i would just be happy rolling around with 500rwhp
What it really comes down to, is who can hook that power to the ground. You can have 1000 HP, but if you just spin the rear's - you lose.
I think the Z has a better chance to put it to the ground all things equal, I put my money on the Z no matter how many HP the coupe has.
EDIT - Special Ed for vettedave, things equal like suspension is stock, no slicks... if you still can't figure out what a level playing field is... wanna race?
Received 1,576 Likes
Interesting thread. I was actually wondering the same thing recently. Will you be taking it to the track? I'd be more concerned with good ET's and personal goals than what it's going to beat on the street. I'm sure it'll be faster than just about any street car that you run into. But the track tells the true story. Mooney, how much boost will you be running?
Lets be real here. More power plus similar weight and drag radials = C6 Z06 losing.
