Dyno results from my 408 vette
Had my car tuned down in Tampa a week or so ago here is the numbers and some pics let me know what you think!
Was super hot out over 100* so when its cooler out i think i can pick up a lil more, given its already corrected but we all know thats always off when cooler outside
Specs
Car- 99 frc corvette torch red
motor-lq9 6.0 bored and stroked to 408ci
texas giant cam 248/254
prc stage 3 heads
callies dragon slayer crank
callies rods
diamond -2cc pistons
fast 102/ nw102 throttle body
ls2 fuel rails
42lb injectors
custom made air intake by me with ls7 maf
monster stage 4 clutch
BILSTEIN suspension
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Specs
prc stage 3 heads
callies rods
ls2 fuel rails
42lb injectors
BILSTEIN suspension
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Received 2,054 Likes
Nice numbers!
thanks, I think it could make more if I got some better heads say afr or trick flow, and ported the 102, but that would cost 3200.00 if not a lil more im super happy with the setup and the way it drives. Still get 16-18 city and 26ish on highway and runs like a champ. I will prob do a 100-150 shot sometime next year but for now im happy going to start to look into scca events in my area
Supporting Vendor
Hi,
I see you have a pressure switch on the fuel rail, what is that for?
Also what pig tail did you used to adapt the LS7 MAF? I am putting
one on my 02 z06 that is why I ask.
Christian
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
