Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Fartpipe goes 10.424@134.24mph 1.582 60ft Stock ZR1 w/DR's
Old 02-19-2012, 12:41 PM
123sugey
Dig
Support Corvetteforum!
123sugey's Avatar
Very cool !!
Old 02-19-2012, 01:30 PM
Chris Stewart
Chris Stewart's Avatar
Originally Posted by Rick@RKT56
Congrats Bruce! This is the MONEY shot!!!!!!!!
Very nice! Is that with stock suspension or front sway bar removed?
Old 02-19-2012, 03:47 PM
Fartpipe
Fartpipe's Avatar
100% stock and OMFG that picture is worth a MILLION BUCKS!!!!!!!!!! WOW!!!!!!!!!!!!!!
Old 02-19-2012, 03:53 PM
Dirk Diggler
5th Gear
Dirk Diggler's Avatar
Glad you like the pic I sent Rick the 16 mega pixel version
Old 02-19-2012, 03:56 PM
Fartpipe
Fartpipe's Avatar
Rick called me on my way home and said you had it OMFG!!! Send me the pic to my email so I get it raw and dirty to ecurb3@comcast.net
I owe you a serious beer!!! Wow fantastic shot!!!
Old 02-19-2012, 04:04 PM
Rick@RKT Performance
Supporting Vendor
Rick@RKT Performance's Avatar
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
Larry took the money shot. Here are some more.
__________________
Old 02-19-2012, 04:10 PM
Rob Petyo
Rob Petyo's Avatar
That's awesome I'm almost as fast as a built heads,cam,intake,stahled,geared,drag wheel running 346ci c5 that's lighter than my car. Good point did you wanna bring up your fox body mustang runs 9s for $2000 too?
No, but it would be cool to put a bar in it and run the Corvette Challenge 10.50 or or brackets and see what that thing can obtain ...
Old 02-19-2012, 04:25 PM
Dirk Diggler
5th Gear
Here are all of the uncom[ressed images right click save as will get you there. Your email bounced them back because the attachments were to large even though I broke them down to 20 MB zip files
Old 02-19-2012, 04:31 PM
94z28racecar
94z28racecar's Avatar
Congrats Bruce!!!
Old 02-19-2012, 05:06 PM
baezi z06
baezi z06's Avatar
Damn that´s nice.....
Congrads Bruce you did it again
baezi
Old 02-19-2012, 05:39 PM
Fartpipe
Fartpipe's Avatar
Thanks for the grats everyone. I look forward to going faster for everyone!!!
Old 02-19-2012, 06:04 PM
EVIL_C5
Uber Waxer
EVIL_C5's Avatar
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
Serious beer for Larry could get costly....lol
I was hoping to get all the way down the track to see if I could get a 40 or 50
That's a poster pic for sure
Old 02-19-2012, 07:27 PM
  #33
Joe_G
Joe_G's Avatar
St. Jude Donor '08
Default And now for some analysis....
Here is FARTPIPE's scan on the 10.42 pass.
Some interesting things to note.
1. Launch rpm = 4373, 100% throttle, full boost of 8.2 psi (calculated as the scanned map of 22.9 psi - 14.71 baro (per dragtimes, @ 3 pm, 54 degrees, 44% humidity, 29.95 baro, (29.95 inches of mercury = 14.71 psi), = (204) DA). I'm assuming on these blower calcs as I'm a N/A guy...I look for .99-100 kpa and know my filter's not plugged and I'm good.
2. Interestingly, the car was revving up to 5357 under about 1/2 throttle, then FARTPIPE floored it, the RPM's went down to 4307, boost was building to max of 8.2 during that time...up to 4373 as the car spun just a smigen at launch (FARTPIPE compensated by reducing throttle 5% for .130 of a second), then bogged down to 3424 during the launch sequence (all at 100% throttle). Not sure why the RPM's went down when he floored it, clutch in, from where it was at 1/2 throttle...must be some sort of torque management kicking in. My car doesn't do that.
Some data:
0-60 time = 2.195 seconds...though if his DR's are shorter than stock that time is a little off...still...blazing fast...assuming they are short, even using 0-65 mph it's 2.455...handily beating the Veyron.
60-130 time = 6.165 seconds.
1-2 shift time, .195 seconds, 6,564 rpm.
2-3 shift time, .260 seconds, 6,621 rpm.
3-4 shift time, .195 seconds, 6,813 rpm. I wonder if FARTPIPE went clutch in before letting off the gas on 3-4, as you can see the rpm flare up to 6,922 when he was off the gas.
It appears the scanner only reads time in .065 increments...3x.065=.195 so the shifts were likely between .130 seconds and .195 seconds, but below .195 except for the 2-3.
FARTPIPE got about 13 mph wheel spin on the 1-2 shift, 8 mph on the 2-3 shift, and 10 mph on the 3-4. Some ET left on the table there, but I couldn't find any other ET left on the table.
Car was running about 26 degrees timing, IAT at the start of the run was 75, going down to 63 degrees in 4th gear through the end of the run. I'm not familiar if that's the pre-blower IAT or the IAT after compression on the pid that was scanned. My .cfg wouldn't read the knock sensor for some reason but based on the commanded timing line I don't think it had any knock. Interesting that this blown car takes more timing than my N/A car.
FARTPIPE ran it to 6400 in 4th...145 mph....in 10.65 seconds. Feels good to go that fast. I won't type how long it took my car to go 145.
Overall, one of the cleanest runs I've ever reviewed.
Hats off to you FARTPIPE. You drove that car yesterday.
Old 02-19-2012, 07:53 PM
  #34
robz
robz's Avatar
Very nice Bruce.
Old 02-19-2012, 10:03 PM
  #35
FSTFRC
FSTFRC's Avatar
Great driving Bruce aka Fartpipe! congratulations on reaching your goal.
Old 02-19-2012, 10:19 PM
  #36
Fartpipe
Fartpipe's Avatar
Thank you!
Added go pro videos
Old 02-19-2012, 10:58 PM
  #37
Blackbenzz
Blackbenzz's Avatar
Congrats Bruce! Nice driving!!! Good catching up with you for a bit yesterday
To Fartpipe goes 10.424@134.24mph 1.582 60ft Stock ZR1 w/DR's
Old 02-19-2012, 11:50 PM
  #38
nickolbag
nickolbag's Avatar
The C5 ZR1 looks a lot like a C6.
Old 02-20-2012, 12:04 AM
  #39
Joe_G
Joe_G's Avatar
St. Jude Donor '08
Thank you!
Added go pro videos
Quote me and see how to make the videos appear in the post.
Old 02-20-2012, 12:10 AM
  #40
skull
skull's Avatar
good job fartpipe! to bad i only got to watch your 10.5 pass.
kudos to you
Quick Reply: Fartpipe goes 10.424@134.24mph 1.582 60ft Stock ZR1 w/DR's
