AES 427 stroker. SDPC CNC'd LS3 heads. 560 rwhp/ 500 rwtq. Tuned by Wong Performance.
2000 Corvette FRC
AES 427 Stroker 11.75:1
Lunati Voodoo 243/255 .651/.651 112+2
SDPC CNC'd LS3s w/ PRC .675s (milled 30 thousandths)
LS7 intake
LS7 MAF
FAST 102mm
Comtec 100mm Throttle Body
Kooks 1&7/8s
Kooks 3" Xpipe
Borla Stingers
Textralia 0Z 700
Pfadt Racing shocks
Tuned by Tom Wong at Wong's Performance Engineering in washington
Final numbers are 556 rwhp and 496 rwtq. Really nice flat torque curve at 500 right across.
Tom said the fuel pump was running out above 6800, so I'll upgrade around spring time.
Also having him install a built rear end with 3:73s, C6Z axles and carbon clutch packs around tax return time.
This thing sounds PISSED at an idle. It just wants to take off. Still breaking it in. Going to do another oil change. then 1 more after a couple hundred miles just to make sure
Heres a few more pics of it getting the swap.
Big thanks to,
Fraser at AES
Jesse at SDPC
Tom at Wong Performance
LS7 intake
LS7 MAF
FAST 102mm
Kooks 1&7/8s
Kooks 3" Xpipe
Borla Stingers
Textralia 0Z 700
Pfadt Racing shocks
Big thanks to,
Fraser at AES
Jesse at SDPC
Let me know when you take it to Woodburn for some passes. I'll come down and run with you.
I followed along on FB. I need to get out there and visit with Tom soon.
Congrats!
Ron
Congrats!
Ron
Wow! Nothing Wong with that! Sorry had to do it. Nice numbers. I am getting ready to start my own 427 build soon. I might have to bug you for some info. Good luck with it. Can't wait to see a video of it running.
But i cant afford to break anything now so probably wont be up at woodburn this year.
thanks guys. heres a quick cold start idle.
http://www.youtube.com/watch?v=i3EcdO4g53k
[QUOTE=Spectre86;1581679923]Ron, probably wont do any running this year. motor only has about 300 miles on it. Doing an oil change on wed, then another at 1000 miles. then ill start playing a bit.
thanks guys.
I understand. We don't need busted parts.
Ron
thanks guys.
Ron
Received 1,762 Likes
Very nice numbers! I am planning a similar build.
Was the C6 LS7 air intake a pretty easy fit in the C5? I like the way they look, and the width of them appears to allow quite a bit of air volume.
