Your C5 1/4 mile quick list!
#241
2002 Z06
26x11.5x16 MT ET Street Bias Ply on 16" corvette wheels, gto skinnies with MT Sportsman Front runners
Performance Mods: A&A V2 S with MI, LT headers, Mcleod RST Clutch, C6Z guts in my rear diff
Which category: Manual quick list - Gear jammers
60'.............1.957
330'...........5.059
660'...........7.423
660’ mph...105.2
1000'..........9.448
1320'..........11.120
1320’ mph…132.71
Comments: Texas Motorplex, 437 ft DA. Only was able to make 2 passes, STILL working on my 60's.
660’ mph...105.2
1320’ mph…132.71
#242
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Rob, time to move up to #2 on the 346+ NA C5 list...
Date of pass 11/18/16
DA ~ 600'
1999 coupe
LS7 427
LSX-LS7 heads.
Holley Hi-Ram intake
Brian Tooley Racing custom spec hydraulic cam
Fuel - E85
TH400 Trans
TCI converter
C6 diff - 3.73 gear
28" ET drag slick
Weight with driver - 3050
9.45@141
Top ten 60' list too
https://www.corvetteforum.com/forums...-red-sled.html
DA ~ 600'
1999 coupe
LS7 427
LSX-LS7 heads.
Fuel - E85
TH400 Trans
TCI converter
C6 diff - 3.73 gear
28" ET drag slick
9.45@141
#243
Results from MIR track rental
1997 C5 Base
305/45-17 Mickey Thompson Street R on 17 x 11 Weld RT-S rims.
P1SC-1 Supercharged 408 built way back in 2008.
346+ power adder class
60'.............1.349
330'...........3.754
660'...........5.764
660’ mph...121.78
1000'..........7.497
1320'..........8.962
1320’ mph…153.98
MIR track rental 11-18-16. DA +583 @ 3PM when the pass was made.
LS2 based 408, 10.75 compression ratio, RPM Level VII 4l60e with Yank PY3600 converter, 3.15 gears. Vid of run below. Driver on this pass: Robert Johnson. Mechanic/Tuner: Mayhem Motorsports in Raleigh. Jay Garlington contact person and owner there. Trying the new suspension and tires. Still have a ways to go as witnessed by the launch. It's compromised badly so there's still quite a bit left on the table from this pass. Car is still way too heavy at 3140 w/o driver.
660’ mph...121.78
1320’ mph…153.98
The following 2 users liked this post by Rob Petyo:
C5 Pete (11-20-2016),
smokinstorm (11-20-2016)
#247
If you would like to be on the list please supply a slip and some details.
#248
Thanks Hot Wheels!
2001 Z06
Hoosier DRs 275/40/17 on Y2K wheels, GTO spares w/ Moroso frontrunners
2001 C5Z
SBE LS6 (346ci)
A&A Vortech V2 (12lbs)
ARUN Jam Cam
LG Longtubes
Corsa Extreme
Alky Control
McLeod RXT w/ AL flywheel
RKT56 trans
built differential
Manual Fast List Gear Jammers
60'............. 1.760
330'........... 4.573
660'........... 6.842
660’ mph... 107.83
1000'.......... 8.793
1320'.......... 10.408
1320’ mph… 140.72
MIR, 68*, 400' DA
SBE LS6 (346ci) M6
6) 10.408 @ 140.72 - Demonicbird00
Brandon
2001 Z06
2001 C5Z
SBE LS6 (346ci)
ARUN Jam Cam
LG Longtubes
Corsa Extreme
Alky Control
RKT56 trans
built differential
660’ mph... 107.83
1320’ mph… 140.72
MIR, 68*, 400' DA
SBE LS6 (346ci) M6
Brandon
#249
First run at the track
Year of the C5: 2003 A4
Tires used on the pass, size / brand/ etc : Bridgestone RE11, Stock Size
Performance Mods (if any).: TSP Long Tube Headers and Catted X Pipe, K&N CAI with Bridge, MSD Plug Wires, Dyno Tune by Engine Logics, 160 T Stat
Which category?
60'............. 1.9968
330'........... 5.4360
660'...........
660’ mph...
1000'.......... 10.6541
1320'.......... 12.7129
1320’ mph… 107.37
Comments: name of the track; weather conditions. Density Altitude, if known: Run at Lone Star Motorsports Park, Sealy, TX.
Which category?
660'...........
660’ mph...
1320’ mph… 107.37
#250
Our C5 441cu.in LSX block NA got 10.4sec on quarter mile. engine build and tune at Performance Workshop here in UAE
#251
https://www.instagram.com/p/BQAHCDjg1Kd/?hl=en
#252
c5z stock 6 speed
may I get on the 1/4 mile manual list please ? I know theres alot faster cars not on the list but I want to joing list Thanks in advance
2003 z06 Stock Long Block
26x8.5 hoosier on 15"
bolt ons/off and Nitrous
60'.............1.512
330'...........4.210
660'...........6.383
660’ mph...110.83
1000'..........8.278
1320'..........9.857
1320’ mph…143.09
Mir no excuse Da but ill say it was close to 800 da if I recall correctly
missed 4th on this run cost 3mph and what I believe would been 2 tenths...
660’ mph...110.83
1320’ mph…143.09
Gxpz06 (02-15-2017)
#254
#256
2002 Z06
mods are as follows
callaway honker
breathless shifter
ls7 clutch
kooks long tubes cat delete
factory ti's
Hawks custom cam
hawks tune
7.54 @ 94 mph
hoosier dot 315 35 17 'a
mods are as follows
callaway honker
breathless shifter
ls7 clutch
factory ti's
Hawks custom cam
hawks tune
7.54 @ 94 mph
#258
1999 FRC
(Left lane)
Track: Wildhorse pass raceway (chandler,AZ)
Tires: Nitto NT05R 305/45/15
Transmission: M6
Motor: stock heads, stock block, no cam
Mods: procharger D1(9psi), kooks 1 7/8" LTH, 3" X pipe(no cats), E85(aka E54 here in AZ), 60lbs injectors, hardwired walboro 450.
#260
2002 C5 base- 6 speed, 3.42 gears
Mods- ported 243's, XsPower long tubes with catless mid, 228r cam, breathless performance CAI, centerforce dual friction clutch. Street tires.
