drag tips for noobs
drag tips for noobs
first time ever going to the drag strip I wanted to know you guys have any tips for me to get the best 1/4 mile time all I have is just for Borla exhaust and just regular street tires . Do you guys prefer competitive driving mode or just no traction off and what's the best rpm to launch at? and any other advice would be much appreciated
Don't try to get the best possible run out of your car, or rotate the earth beneath you when you launch it. Get comfortable with driving on the dragstrip, and learn how your car reacts and drives before really beating on it.
You'll save yourself embarrassment and possibly a crash by not trying to make it all happen the first time out.
If you've never ran anything at the track before, I'd leave your traction control on and get a feel for the car, then work your way up to it. I'm on stock runflats at the moment and its a little sketchy to launch on them, I had to feather it pretty good and I'm on stock power.
1. Just remember that you cannot do a burnout with traction control on. Competitive Mode was used on the C5Z to still have AH engaged. A burnout is not necessary if you would leave like you are starting off at a traffic signal.
2. Do not air street tires down below 24 psi.
3. If you get wheelhop, ABORT pass immediately.
4. When you stage the car, slowly drive in to light the TOP bulb, then stop. Slowly creep in to light the second bulb, then stop immediately.
5. Most of all, have fun.
Spend your first visit at the track just getting used to how everything works - how they run the staging lanes, do they want cars on street tires to drive around the water box instead of through it, getting the car positioned properly in the beams, etc.
Dig
The first thing I do when going to a new track is go online and see the birds eye view of the track. This way you can see where the turn off lanes at the end of the 1/4 are and a general idea of the track itself.
Have fun
Have fun
Anyone know what rpms to launch a stick at?
That's going to depend on a lot of variables. Your driving abilities, what tires you're on, gearing, clutch, etc. find what works for you and what gets you the best 60' time. My old camaro loved 4000-4500 rpm dumps but it was sitting on a 9" w/ 3.90 gears and 28" slicks with a monster stage 3 clutch.
Take off like you are going to turn left in front of on coming traffic on the street. That should get you launched pretty decent.
Track prep and track temps are critical as well.
Just my opinion..but if I were you I would maybe rev to about 2000rpm and on the second yellow light, slowly get into the gas as you slip the clutch pretty fast. If you get too hard into the gas right away you will probably just spin.
OP- Since this is your first time, try this. Do not try to hit a Home Run the first time out.
The below link will answer many questions. Ranger has taught many of us.
http://www.rangeracceleration.com/
Try that with a Vette and the rear will be all over the track.
1 Post
Here is the biggest tip that everyone forgot. If you start spinning the tires let off the gas and don't floor it again. You will just unload the tires and get yourself in trouble. If your spinning the tires your ET is shot anyway so just drive it to the end, don't floor it. I have seen 2 inexperienced drivers crash their Vettes by getting back on the gas after spinning street tires.
Hope this helps.
Mike V
Hope this helps.
Mike V
Hope this helps.
Mike V
Hope this helps.
Mike V
I also am a newbie to the drag strip. I'll be running my 97 coupe 6 speed for the first time tomorrow morning at Englishtown NJ. I just finished getting the long tubes, x pipe and borla kit on it and a bbk cold air intake. Got it dynoed and now ready to go!
I feel as though I am a good driver but well see tomorrow. What can I expect to see and feel? What numbers for 1/4 and any pointers.
Wish me luck!
Wish me luck!
Wish me luck!
Wish me luck!
Drag Strip Noob
