Need help for drag tire
This weekend, race on well prep track (i think, in the 3 best track for 60ft in europe, after Santa Pod and perhaps hockenheim), but, it's only a airfield who is using 5 times a year this year (and just twice last year).
So, i was hoping to hit the 10 (11.1 last month with 1.7 60ft with my SC/header/640 lift blower cam/e85/STOCK MN6/rear/axles/5 years ET-Street/DEAD CLUTCH)
So, i replace the clutch for a Spec3+ ;-)
BUT, when putting my left ET street (17/11.5/26), i see he is DEAD (seeing the ROPE on 1/3 circumference and 1 inch width... WOOW)
So, i have race (13 passes), the tire doesnt broke (i'm Lucky, i know), but not possible to do better than 1.761 60ff/11.211 and LOOSING 3 or 4 mph
I NEED NEW TIRE ;-)
Two solution for whell :
The actual C4 ZR1 17inch i use now (10" wide)
Or camaro 4th 16inch i can have at good price (8" wide), just have to grid a little the brake
What choice for tire ?
Buy the same ET STREET in 17/11.5/26 inch ?
Or buy Hoosier ?
2013 QUICK TIME PRO D.O.T.
Item Tire Size Tread Tread Approx. Approx. Recom. Measured Section Tire Model
Number Pattern Width Dia Circ Rim Rim * Width Weight
17431 26x 9.50-16LT D 8.0" 26.1" 82.0" 6-8" 8" 9.3" 18 Quick Time Pro (less wide than ET Street, but 16"... what's better ?)
17603 28x11.50-16LT D 10.0" 28.0" 88.0" 8-10" 10" 11.8" 24 Quick Time Pro (as wider than ET Street, but 16", and 28"... what's better ?)
2013 DRAG RACING
18157 28.0/10.0-17 C 9.5" 28.0" 88.0" 8-10" 8" 11.3" 23 D06(less wide than ET Street, but 28", and other Compound... what's better ?)
Thanks ;-)
I NEED NEW TIRE ;-)
Or buy Hoosier ?
2013 DRAG RACING
Thanks ;-)
