01 Z06: Dyno Results Before/After LG/Vararam
I am happy with the results and figured I would post them up. Tuner spent time on drivability tuning while on the street and then tuned WOT on the dyno. I can tell a big difference in how smooth it is just driving around normal and although it doesn't seem like a large gain it is noticeable for sure.
Car:
01 Z06 - 21,000 miles Canadian Model
Base pull was Bone Stock (or so I thought at the time. When I removed the stock air bridge and box I did find a K&N Panel filter in the stock airbox)
The next pull shown on the graph is 2 weeks later on the same dyno after the install of a Vararam and LG Super Pro headers and being tuned.
I didn't remove the stock screen inside the 01 MAF or make any other mods other than the LG super Pro system and the Vararam. I am still running the stock Ti mufflers.
The car feels so much smoother and I love the sound once you get in it. The added power increase is noticeable throughout the entire RPM range.
If the numbers aren't readable on the chart:
Base Pull Stock: HP: 349.69, Torque 352.64 ft/lbs
After Mods / Tune: HP 376.15, Torque 374.30 ft/lbs
Car:
That's a nice gain. Probably more from the headers but the VR helps too. Keeps the IAT close to or at ambient.
Don't remove the MAFscreen. You will need a retune if you do.
Ron
Ron
