Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
MIR WCF All Motor Class New Rules Coming Out
Old 08-27-2014, 09:44 PM
GARY2004Z06
Support Corvetteforum!
GARY2004Z06's Avatar
Default MIR WCF All Motor Class New Rules Coming Out
Just got off the phone with Jason Miller. Since GM is not represented in this class, we thoroughly discussed how we can get cars involved. The new rules are to be out soon. (I'll keep everyone posted.) In a nut shell, we are getting a break with weight reduction. This is huge for all of us wishing to compete. The LS1 & LS6 cam only crowd will get the biggest break. The bolt-on only LS7 guys and gals will be 150 lbs. heavier. LS2 and LS3 cars will fall somewhere in between. Please let us know if you have any interest in running to put on a good show for the crowd and represent.
Who knows, maybe we will get to eat some rice.
Old 08-28-2014, 04:40 PM
Rob Petyo
Rob Petyo's Avatar
Old 09-01-2014, 08:11 PM
GARY2004Z06
Here you go.
2014 ALL MOTOR
http://www.importvsdomestic.com/rule...r_domestic.pdf
2014 WCF RULEBOOK ALL -MOTOR (DOMESTIC)
POSTED 9/01/14
M A R Y L A N D I N T ' L R A C E W A Y W O R L D C U P F I N A L S Page 1 of 2
Class Designation: The class designation is: A/M
General Safety: All vehicles must conform with general IHRA safety rules.
Body: Any year vehicle is allowed. Lightweight components are limited to hood, front fenders, decklid, hatches, sunroofs, wings, ground effects, and bumpers only. Roof, Quarter panels, and doors must remain
steel. One-piece front ends are not permitted. No body parts may be removed during competition.
Chassis: All cars must retain complete stock chassis, floorboard, firewall, and frame rails. Notching of chassis for clearance is permitted. Aftermarket “K” members are permitted.
Suspension: All cars must utilize stock front and rear suspension and mounts. Aftermarket front control arms, rear control arms, and sub-frame connectors are permitted. Aftermarket struts and shocks are
permitted. Ladder bars, four links, and wheelie bars are prohibited on all cars.
Lights: Headlights and brake lights are required (one headlight may be removed for induction).
Windows: All windows must be OEM glass.
Interior: Stock dashboard and full interior from front seats forward is required (passenger seat may be removed). Aftermarket seats, gauges, and interior are permitted.
Exhaust: Muffler(s) are required unless vehicle is turbocharged. Exhaust may exit anywhere.
Electronics: Two-steps, data loggers, aftermarket ECU’s, and engine management systems are allowed.
Driveline: Aftermarket axles, ring and pinions, final drive, spools, and differentials are permitted. Other OEM or aftermarket center sections and rear-ends may be replaced only if is a direct bolt in. IRS suspension
cars may convert to straight axle only if it is a direct bolt in.
Transmission: Manual or Auto transmissions are permitted. Any style automatic transmission is permitted. Trans-brakes are permitted. Manual transmissions are permitted to use aftermarket stock-style clutchassisted
transmissions. Sequential transmissions are prohibited. Aftermarket bell housings are permitted.
Clutch: Three discs maximum (any type of disk material is permitted). Clutch must be manually operated by driver’s foot.
Shifter: Shifter must be H-pattern. Strain gauges are permitted. Air shifters are prohibited.
Fuel: Gasoline and E-85 permitted. Alcohol is prohibited.
Fuel System: Electric fuel pumps only are permitted. Aftermarket fuel cells are permitted, and may be mounted anywhere.
Oiling System: Dry sump oil system is only permitted if car was OEM equipped with a dry sump and car is using complete OEM oiling system.
Tires: Maximum size slick or bias ply tire is 28.0” x 11.5”. Any size DOT radial tire is permitted, except 315/60/15, 325/50/15, 295/55/15, or 295/60/15.
8-Cylinder Engines – Chevy LS series
Engine: LS1, LS2, LS3, LS6, and LS7 series blocks permitted. No aftermarket blocks are permitted. Internal engine modifications are prohibited except for aftermarket camshaft, hydraulic lifters,
valve train, and overbore (See chart below for max CID).
Description: This is a cam only class with bolt-ons.
Bolt-Ons: External bolt-on parts are permitted.
Camshaft: LS1, LS2, LS3, and LS6 cars are permitted to run any hydraulic camshaft. LS7cars must run OEM camshaft and OEM valve train.
Induction: Engine must be EFI. All OEM intakes are permitted. The only aftermarket intakes permitted are: BBK intakes, Typhoon intakes, and Fast 78mm, 90mm, 92mm, and 102mm intakes.
Cylinder Heads: Un-Ported as cast cylinder heads only, porting prohibited. Any valve job is permitted. No milling of cylinder head. OEM cylinder heads only are permitted with the following casting
numbers: 241, 243, 317, 706, 799, 853, 862, 8452.
Power Adders: Turbochargers, Superchargers, and Nitrous Oxide are prohibited. All nitrous bottles and solenoids must be removed from car and nitrous nozzles must be capped.
Driveline Block Cylinder Heads Max Displacement Car & Driver Minimum Weight
Straight Axle or IRS LS1 LS1, LS2, LS3 or LS6 heads 348ci. Max 2750 lbs.
Straight Axle or IRS LS6 LS1, LS2, LS3 or LS6 heads 348ci. Max 2750 lbs.
Straight Axle or IRS LS2 LS1, LS2, LS3 or LS6 heads 366ci. Max 2850 lbs.
Straight Axle or IRS LS3 LS1, LS2, LS3 or LS6 heads 380ci. Max 3050 lbs.
IRS Only LS7 LS7 heads 427ci. Max 3050 lbs.
* Manual transmission: Deduct 100 lbs.
* Cars with IRS: Deduct 50 lbs.
* Cars equipped with LS3 Heads: Add 50 lbs.
* LS7 cars equipped with aftermarket cam: Add 150 lbs.
2014 WCF Rules
http://www.importvsdomestic.com/rulebook/
Big weight reductions so we can finally compete.
Old 09-05-2014, 11:56 AM
Rob Petyo
Rob Petyo's Avatar
Can you please explain this?
Does this mean I would be competing against someone (car & driver) about 2,700 pounds? I don't think my coupe would stand a chance.
Would my 382 fit in with the LS6 block?
Old 09-05-2014, 12:48 PM
LSOHOLIC
LSOHOLIC's Avatar
The way I read it is...its basically a cam only class with full bolt-ons. OEM heads unaltered...in anyway.
The rules will favor a purpose built machine, specifically for "their" rules.
The only mods allowed are; Internal engine modifications are prohibited except for aftermarket camshaft, hydraulic lifters,
valve train, and overbore (See chart below for max CID) .
So looking at the weights, it would pay to max out the cubes as well as your dynamic compression (overbore; aka, some big domed slugs with nice valve reliefs) and put the bit*h on E85. With a big nasty cam and try like hell to make the minimum weight...good luck. Unless its just a gutted racecar.
With the right combo I could see 500rwhp @ 2850 being somewhat competitive. But is obvious to me that the rules still favor the imports.
I've heard that is was a deliberate move because.....the imports are less reliable and have trouble going rounds.
But it would still be fun for sure !
IMO, this is a 10.2 -10.4 class for a IRS vette but the imports will be running 9.7 - 10'ohs.
Old 09-05-2014, 05:02 PM
Rob Petyo
Rob Petyo's Avatar
Totally agree!
However, what does look like a LOT of fun to me is the 10.50 index import / domestic ...
If this old man can cut a decent light (going deep) on a .400 pro tree, I could only hope to qualify. Ran this at E-Town once and did pretty well.
Have to be careful with getting a flat when the inports are runninng, leaving junk all over the place. I stoped it because of the flat tires...
This might be fun
Old 09-05-2014, 06:09 PM
dennis50nj
dennis50nj's Avatar
Totally agree!
This might be fun
the wild rice is very sharp like tacks
Old 09-05-2014, 11:07 PM
C5 Pete
AMP Racing
C5 Pete's Avatar
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
I don't believe deep staging is allowed.
I can put stock LS 7 heads on my car and weigh 3150.
I'm allowed a valve job.
I plan to swap cams and find some heads and run 9.70/80
Old 09-06-2014, 12:05 PM
LSOHOLIC
LSOHOLIC's Avatar
Thats very impressive Pete...what cube are you ??
I hope to see several of you NE guys compete in this race.
Old 09-06-2014, 09:49 PM
C5 Pete
AMP Racing
C5 Pete's Avatar
I've got an LS7-427
Old 09-07-2014, 06:06 PM
LSOHOLIC
LSOHOLIC's Avatar
I've got an LS7-427
Lol....what am I missing Pete ??
And stock headed & stock cam LS7 will run a 9.7@3150lbs in average air in your car ??
Am I understanding you correctly ??
Old 09-07-2014, 06:12 PM
C5 Pete
AMP Racing
C5 Pete's Avatar
At 3150 lbs I can run an aftermarket cam. Stock heads.
Old 09-07-2014, 06:52 PM
LSOHOLIC
LSOHOLIC's Avatar
Ok....what does this statement mean ?
Old 09-07-2014, 06:55 PM
C5 Pete
AMP Racing
C5 Pete's Avatar
Read the fine print my friend.
LS 7 with cam - add 150 lbs
Old 09-07-2014, 07:02 PM
LSOHOLIC
LSOHOLIC's Avatar
Yep....lol...there it is in black and white...lol.
Gunna need to loosen up the converter a little ??
Good luck....
Old 09-07-2014, 10:21 PM
C5 Pete
AMP Racing
C5 Pete's Avatar
I broke my flex plate at LS Fest so I'm gonna replace it with an SFI one and I've got a new converter for it too - unrelated - I had already planned to swap the converter.
Now I just need to find someone with some stock heads and pick out the proper cam.
To MIR WCF All Motor Class New Rules Coming Out
Quick Reply: MIR WCF All Motor Class New Rules Coming Out
