Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
'02 Z06 'OH JAM' 10.99 @131.4 cam + 150 N2O - 1.9 60 ft - 2100 DA
Old 08-01-2016, 09:05 AM
maroon88iroc
maroon88iroc's Avatar
Default '02 Z06 'OH JAM' 10.99 @131.4 cam + 150 N2O - 1.9 60 ft - 2100 DA
First time out to the track with my car on a good tire and I am thrilled with the results! I have never even ran an 11 in my life. Last time out I ran 12.3 at 119 on street tires, best times last Friday were 11.8 @ 118.32 mph & 10.997 @ 131.38 mph.
'02 Z06 - 120K miles
-stock bottom end, untouched heads, stock intake
-234/240 .605/.617 @ 111 LSA
-Varraram intake
-Longtube headers & Corsa Xtreme
-Built T56 & MGW shifter
-DTE trans/dif brace
-PFADT anti-wheel hop trans mount
-full stock suspension (slammed)
-CCW 17x8 & 16x10 w/ 26x11.5x16 MT ET street @ 11.5 PSI
-Car weighed 3330 with me in it & almost 1/4 tank of gas (I weight 200)
-DA was 2095 per Drag times.com
attached a couple pics and time slips & Video's below:
Old 08-01-2016, 10:24 AM
Gxpz06
Gxpz06's Avatar
very nice surreal that 60ft and still a 10 second pass
what injectors are you running?!
Old 08-01-2016, 01:41 PM
pit-man
pit-man's Avatar
Good run and even better pictures
Old 08-02-2016, 07:54 PM
Glensgages
Glensgages's Avatar
20-30 years ago, many tracks had amateur photographers on-site, but these are very good
Old 02-16-2017, 11:36 AM
maroon88iroc
Forgot to report back I ran 10.33 @ 135 at SGMP in December with the car, no changes other than track and track prep. cut a 1.51 60 ft.
-Gibson
Old 02-17-2017, 04:50 PM
TX Z06 02
TX Z06 02's Avatar
How did you run so consistent on your 60' LOL
That bottom pic is badass with that tire wrinkle!
Old 02-18-2017, 11:29 AM
GARY2004Z06
Support Corvetteforum!
GARY2004Z06's Avatar
Congrats on the 10 second pass.
However, I would caution you about running a non-skinny radial tire up front. The car may get loose.
Old 02-18-2017, 06:17 PM
stratsRR
stratsRR's Avatar
How will running a wide tire up front make it get loose? I've never heard that before. Great runs!
Old 02-18-2017, 09:15 PM
Gxpz06
Gxpz06's Avatar
I could get into the science of it but don't need to ; from over 700 passes in many different stock cars I can tell you with a soft tire/low air pressure in the back and wide radial up front anything in triple digits is your car skiing side to side ; at some point it may get loose and it will be a different conversation ;;;; I've had 245s do okay up to speed s of 120 anything wider and or faster speeds gets really scary real fast
Old 02-21-2017, 10:23 PM
maroon88iroc
The pics in the original post were when I ran it for the first time (my skinny's had an air psi leak so I couldnt use them).. although I did not have any issues with the full size radial front at that track day, I switched to a skinny front with a bias ply tire after that.
To '02 Z06 'OH JAM' 10.99 @131.4 cam + 150 N2O - 1.9 60 ft - 2100 DA
Quick Reply: '02 Z06 'OH JAM' 10.99 @131.4 cam + 150 N2O - 1.9 60 ft - 2100 DA
