A&A 12lbs and Alky dyno numbers inside
run down of my set up
SBE LS6
A&A Vortech V2 kit (12lbs)
LG longtubes
Corsa Extreme
Jam Cam
McLeod RXT w/ AL flywheel
"new" Alky Control
"new" built RKT56 trans
"new" built Differential
previous numbers were 630/532 with 10lbs
added was 3.4 pulley and Alky
new numbers are 680/583
keeping the tune conservative due to the stock bottom end, easily could have gone over 700rwhp
shooting for a 141+ in the 1/4
-Brandon
SBE LS6
LG longtubes
Corsa Extreme
Jam Cam
"new" Alky Control
-Brandon
We're at the same power level and I was able to go 141 mph and make a 9.91 pass. If you can 60ft in the bottom 1.40's you can probably get in the deep 9.80's... Makes for one hell of a streetcar.
Awesome!! Thats good to hear and reassuring!
from my estimate i feel that if i can cut a low 1.5 i could achieve a 9.9...tho im not too worried about ET as much due to being an M6... my goal is 141, and depending on my 60', ET will be the byproduct...
and yes makes for one hell of a FUN street car
are you M6 as well or auto? whats your setup?
-brandon
-brandon
