Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Cam only C5 Z06 makes 440/430 SAE
Old 03-13-2017, 09:57 AM
FASTFATBOY
FASTFATBOY's Avatar
Originally Posted by Hot_Wheels
Nice NUMBERS! I love it when people argue over dyno numbers. There hasn't been this much action around here since the season ended. My impression of a dyno is that they are a "tuning device" and can be used to see what the actual gain of the mods were/are before and after the tune and the addition of a supporting mod.
I'd love to see what it runs in the quarter mile especially what it's mph is. I read it's a road race car and would probably not see any quarter mile tracks but in case you ever do please stop by the sticky at the top of the page and see how you compare. We would be in the same category "Internal Engine Modifications - Head/cam -> 346 " with you putting down about as much rwhp as I do. Unfortunately we do not have a "cam only category". Actually, you have higher numbers but what the heck, they are only numbers. The real number to me is how well it 60 foots and what it will run in the 1/4 or 1/2 mile.
The term cam only has been tossed around for a long time and seems used loosely used but as we all know adding just a cam is a waste without supporting mods. What do I know, I wrote the check because I'm dumb and stupid for not perusing a career in auto mechanics.
Well, the car has a stock clutch in it......although it's relatively new(3500 ish miles) I don't know how much drag strip abuse it would take. I know it wont hook on the Michelin PSS, in 60 degree air you can put the car in 2nd gear at 2500 rpm, turn off trac control.....put it on the floor and it will destroy the PSS. Third gear feels pretty sporty I must say, fourth gear....on the street I don't push it much there as the car is moving pretty hard.
I may take it just to see. What MPH would be expected with 440 to the wheels? 122-123?
Old 03-13-2017, 10:06 AM
Rob Petyo
Rob Petyo's Avatar
IF I get 440 rwhp with the new (LS1 stock cube) setup and tuner, my plan is to make a 9 second pass this fall. Already have been over 130 mph with 418 rwhp. Like I said, to me they are just numbers.
Old 03-13-2017, 10:49 AM
Cjunkie
Cjunkie's Avatar
Lol cam only WTF! This is soooooo GM fanboy!
Old 03-13-2017, 11:21 AM
robz
robz's Avatar
Nice numbers!
FASTFATBOY (03-13-2017)
Old 03-15-2017, 07:36 PM
Scotty2000SS
Scotty2000SS's Avatar
Good job OP!
FASTFATBOY (03-19-2017)
Old 03-19-2017, 09:15 PM
FASTFATBOY
FASTFATBOY's Avatar
I took it to the track, the stock clutch is slipping...even on MPSS. When I go to put the car into gear to make the return road the pedal is mush.
I ran the car to 160mph on the way home and it would not go into 6th gear, I had to wait and pump the clutch.
This is a 3500 mile LS6 replacement clutch.
Best pass
12.14@119.8 with a 2.05 sixty foot.
Time for a stronger clutch.
Old 03-19-2017, 10:30 PM
Roddy13
Roddy13's Avatar
Best pass
Decent! Obviously with a better 60' you'll be in the 11's ... 119mph would reflect closer to 410whp but if your clutch was slipping that would explain the 119. IMO 440 should put you up around 123+. Either way impressive results!
Old 03-20-2017, 03:26 PM
NosLaser
NosLaser's Avatar
On an "official" list this car wouldn't qualify as cam only, but who cares. He listed the mods which is more than what most people would do.
The bump in compression with a proper tune is most certainly worth some power. Nice numbers regardless. Get a clutch in that thing now.
Old 03-20-2017, 11:51 PM
TGO
TGO's Avatar
Car has no headwork. Where did you see head work? "Head work" is milling the heads now?
umm...you yanked the heads off and milled them to increase compression ratio.
By definition that is "head work."
Unless I speak an odd version of English.
Old 03-30-2017, 03:19 AM
RonSSNova
RonSSNova's Avatar
I run a dyno. 5 days a week. It's a Dyno Dynamics.
So last week I tuned a 16 Scat pack with a TVS blower at 13 psi. It made 522 as delivered.
I retuned it and it made 560.
Then put C16 in it. Retuned and it made 660. Quite a nice improvement.
Then I tuned the nitrous. Small shot. It made 760.
We send the sheet showing all 4 runs to the customer and he was puzzled.
He had it dyno'd a month earlier on pump gas and it made 680.........
I've never put either of my cars on there......I'd have to report the numbers here and you guys would go pffffft....weak sauce.
Maybe I should take them where he took his?
Old 04-01-2017, 12:10 AM
Drewstein
Drewstein's Avatar
It's not cam only but still good numbers. OP shouldn't have tried to downplay a complete motor rebuild lol.
Cam only means the heads haven't been off the car since forever.
Old 04-01-2017, 12:31 AM
FASTFATBOY
FASTFATBOY's Avatar
SO the pistons have a 4cc relief, I'm supposed to live with that drop in compression to call it a "cam only" car???
LOL.
Heads have ZERO port work.
Car makes more steam than the "average" (ported)head/cam car, I can live with that.
Old 04-01-2017, 08:17 PM
  #33
Drewstein
Drewstein's Avatar
It better make more because you completely rebuilt the motor. That's why it's not cam only.
Still be proud of the numbers, I bet it's a fun car.
Old 04-12-2017, 08:42 PM
  #34
Dave02C5
Dave02C5's Avatar
sounds right.. my '03 dyno'd 443rwhp .. btr 3 cam only.
runs 11.1 @ 125 .. best I could get out of it
Quick Reply: Cam only C5 Z06 makes 440/430 SAE
