Flow# for dart pro1 head?230
Does anybody here know what the flow# are for the 230 pro1 are, I tried Darts web site but couldn`t pull anything THANKS
my dart pro 1 heads were just flowed with a mild stage 1 port job. I will e-mail the numbers if you would like.
Jerry Myers Twinturbovette.net |
Yes Jerry,would appreciate that very much,heres my email..amxzx11@webtv.net THANKS
ex-gold87: I'm curious, would you post them here as well?
:cheers: |
Dart Pro 1 230's:
Lift Int Exh .200 129 115 .300 184 158 .400 231 185 .500 271 199 .550 288 202 .600 296 205 .650 301 207 .700 308 207 Tested with a 4.155" bore, 2.08" intake & 1.60" exhaust. 28" H20 **************************************** **** Here's the flow #'s for the Dart CNC 227's - 2.080" x 1.625" 28" H20 Lift Int Exh .200 158 117 .300 209 149 .400 257 182 .500 293 211 .600 302 220 .700 309 226 .800 314 232 I got these numbers from Dart directly. :cheers: |
The Dart 227cc is vastly superior to the 230cc because of the altered valve arrangement. I ran them without offset rocker or lifters. Which a smart person would use. They cost about $1000 more than Pro1 200 - 230's
Vetteaddict - The posted 230 figures that 71 listed are for the rough casting. Do your heads show any signs of factory bowl blending and port contouring? The reason I ask is I ordered my original Pro1 215 cc with the optional 2.08/1.625 valves the ports actually arrived at 221 cc. I had them hand port balanced flowed. |
Based on their Pro 1 215cc and Iron Eagle 230cc flow numbers I have I would estimate they would flow out of the box in the 285-295 cfm range at .700 lift. I never trust advertised flow numbers from the manufacterers own website
A cnc'd version of any of these heads vastly improves the flow at an additional cost of at least $1000 as gkull states above:D |
I found a web site the otehr day with all kinds of flow data for all kinds of heads, it even has a cool calculator so you can see at what rpm you should make maz hp, i dont know how accurate it is but id like to know if someone else knows, anyways, heres the site http://users.erols.com/srweiss/tablehdc.htm
