HELP-'92, LT1 Firing Order, OptiSpark Plug Wire Order
What is firing order on '92 LT1 and then order (Plug/Cylinder No.) coming out of the OptiSpark?
Re: HELP-'92, LT1 Firing Order, OptiSpark Plug Wire Order (CarlB)
Its hard to see but the opti spark has the cylinder numbers on the same side that the plug sockets stick out.
Passenger side top to bottom: 4,6,8,2 Driver side top to bottom: 5,3,7,1 |
Firing order for all small-block Chevys is 1-8-4-3-6-5-7-2
On the opti: driver's side, top to bottom, is 5-3-7-1 passenger side, top to bottom, is 4-6-8-2 On the engine: driver side, front to rear, is 1-3-5-7 passenger side, front to rear, is 2-4-6-8. Hope that helps. |
Re: HELP-'92, LT1 Firing Order, OptiSpark Plug Wire Order (JasonL)
Thanks AquaMetallic94LT1 and JasonL. Forum is great!
