C3 Option Breakdown
Good morning from sunny Indiana! Just got electronic copy of GM invoice for our pace car. Exciting! How do you go to next step for breaking down options as to content? For example:
FE7 - gymkhana suspension Which option contains radio and tire size info? Thanks GaryC |
You need to get Yourself a "Corvette Black Book" or one of the
many Restoration books that cover Your year. Really the Black Book is best for the info Your after. Info is probably available on internet also but I dont know xactly where. |
Code Description Quantity
1YZ87 Base Corvette Sport Coupe 40,274 1YZ87/78 Limited Edition Pace Car 6,502 A31 Power Windows 36,931 AU3 Power Door Locks 12,187 B2Z Silver Anniversary Paint 15,283 CC1 Removable Glass Roof Panels 972 C49 Rear Window Defroster 30,912 C60 Air Conditioning 37,638 D35 Sport Mirrors 38,405 FE7 Gymkhana Suspension 12,590 G95 Optional Rear Axle Ratio 382 K30 Cruise Control 31,608 L82 350ci 220hp Engine 12,739 M21 4 Speed Manual Close Ratio 3,385 MX1 Automatic Transmission 38,614 NA6 High Altitude Emissions Equipment - N37 Tilt-Telescopic Steering Column 37,858 QBS White Letter Steel Belted Tires P225/60R15 18,296 QGR White Letter Steel Belted Tires P225/70R15 26,203 UA1 Heavy Duty Battery 28,243 UM2 AM/FM Radio Stereo With 8 Track 20,899 UP6 AM/FM Radio Stereo With CB 7,138 U58 AM/FM Radio Stereo 10,189 U69 AM/FM Radio 2,057 U75 Power Antenna 23,069 U81 Dual Rear Speakers 12,340 YF5 California Emissions Test - YJ8 Aluminum Wheels 28,008 ZN1 Trailer Package 972 ZX2 Convenience Group 37,222 Serial Numbers: 1Z87L8S400001 through 1Z87L8S440274 Fifth Digit Code: L=350ci 175, 185hp, 4=350ci 220hp Suffix: CHW: 350ci, 185hp MT CMR: 350ci, 220hp, MT CLM: 350ci, 185hp AT CMS: 350ci, 220hp AT CLR: 350ci, 175hp AT CE CUT: 350ci, 185hp, AT CLS: 350ci, 175hp HA AT CE=California Emissions, MT=Manual Trans, AT=Automatic Trans, AC=Air Conditioning, AH=Aluminum Heads, HA=High Altitude Base Engine: 350ci V8 185hp :cheers: |
pace car came standard with an am/fm stereo 8 track radio. the upgrade was a $650 + addition up to an am/fm/CB stereo radio. basically there weren't a lot of options on the pace car as it came standard with just about all the power "conveniences" as part of the package. alternate rearend gearing, trans selection (no additional charge) and suspension were just about all you could "opt" in for.
the corvette black book is a necessary (in my opinion, mandatory) part of any corvette owner's library. it is sized to make it easy to carry around and is chock full of valuable year to year information. steve |
Don't you love how people go "Why didn't you get it with a 4 speed?!" when you tell them your vette is an automatic? Notice how few vettes even had 4 speeds. :lol:
Thanks all for the feedback. What is the Black Book? See an NCRS technical book for 78-79 vette - is this it? I'm trying to build my library, but you all have a big head start on me.
So far I have Pace Car Owners Manual, '78 Shop Manual, '78 Assembly manual, GM Invoice, Window sticker (on order). I have the option lists as printed in a couple sites, but some options contain multiple things - that's what I'm looking for. ie. what is included in the gymkhana suspension option??? Thanks folks Gary C '78 Pace Car |
Call GM for a restoration package. It should have all the info you need for your year.
Black Book just ordered from Amazon. Info that was just given to me as to what the gymkhana option contained - can this be found within the Black Book?
thanks GaryC |
Black Books
You can find Black Books in any Barnes & Noble's "Transportation" section with other Corvette lit..
thanks GaryC |
Great info as to option content! Thanks! That's where I want my search to end up. Piece by piece we'll get the build info.
Take care and happy cruisin'. GaryC '78 Pace Car |
the 1978 with the optional FE7 suspension had a 6-leaf steel spring versus the standard 9 x leaf of that year. Previous years had 7 or 9 leaf springs. According to Richard Prince's book "CORVETTE 1968-1982 Restoration Guide" p. 221, the 9 x leaf springs were painted light gray and the plastic liners were painted light gray as well. However the 78-79 cars with the optional FE7 had the 6-leaf steel spring and the spring leafs are painted light gray, but the plastic liners are not.
The 6-leaf rear spring is 2 1/4 inches wide, while the standard suspension rear spring is 2 1/2 inches wide. Hence the FE7 springs have two spacers fore/aft when mounted to the differntial. FE7 suspension also had the rear stabilizer bar, 9/16 inches in diameter. Good luck - Swede |
For someone doing 'the right resto', must be a huge task to get everything just right. Understatement I'm sure. Just seeing the variations in feedback as to my question on gymkhana option is awakening. 9 leaf, maybe 7 leaf, could be 6 leaf, 7/16 rear bar, 9/16 rear bar. Not poking at answers, just highlighting difficulty in getting to the correct information for your car.
Thank you all again. Gary C '78 Pace Car |
