Icm?
I keep seeing the acronym ICM now which I have never seen before. Is that the same as the ECM, i.e., main computer, or is that another computer separate from the ECM. Remember, there are no stupid ?s.
zzzasy '96 LT4 |
I haven't seen that one. I know my '95 has a PCM, (which is what the ECM became after the advent of electronic transmissions) a CCM and the module that controls the ABS and ASR. I'm not sure what the acronym is for it. I do know this though, there are far too many acronyms in the world today, we old guys can't keep up! :willy: :lol:
I somewhere picked up "ignition coil modual" for ICM .
Thanks guys
zzzasy '96 LT4 |
Yep, it's an Ignition Control Module. The ICM is a small component located with the coil. It's supposed to have a heatsink grease compound behind it to help transfer heat to the bracket. If it gets too hot, it can cause performance problems.
