Ignition Points Adjustment Tool
Where can I purchase an ignition points adjustment tool?
For a stock distributor you need a flat head screwdriver to adjust the points mount and a 1/8" allen wrench to adjust the dwell. You also need a dwell meter (set to about 30º) unless you want to use a points gap gauge (set to .019"). All of these tools are available at almost any parts store.
What I am looking for is a long flexible shaft screw driver with a 1/8" allen head on the end.
I have one that hasn't been used in years...PM me your address and it's your's :cheers:
I never knew such a thing existed. Is there any advantage over a regular little L-shaped allen wrench? |
Nice thing about the flex driver is, you can set it in there and know your not gonna get a shock. (btw, remember to re-check your timing once you have done the points)
http://www.kd-tools.com/2539.htm |
Originally Posted by mirrorfinishman
Here is the one I have got. Of course, like AJ Foyt would say, mine was handed down from my father to me.
http://www.kd-tools.com/2539.htm Bill |
i would be carefull giving these tools away,100 years from now they will be worth a lot of cash on e-bay . even better if they had been used on vettes, hahahah:thumbs:
