DTC 492 Dealer denies warranty claim
I am not sure if this is the proper forum for this post but here goes. I did do a search on 492 and it looks like some get the code with a FIPK kit which I do not have.
The car is an '04 Z06 with long tube headers and Bassani exhaust from the headers back. The car also has a Vinci installed cold air intake, cooling upgrade and tune as well. All of the mods were done ~3000 miles ago and the car has run great. Last week I got a check engine light. It turns out the code was 492 which apparently is somewhat odd. Bank 2 secondary air intake i.e. air valve. I checked with a chevy tech before I took the car to the local dealer and he indicated the code usually shows up after the car has sat for a while and some rust from water vapor triggers it and it has nothing to do with the headers etc. The car has 7400 miles on it so I took it to the dealer for the warranty repair. Guess what? Surprise, surprise. Oh we can't fix that unless the car is taken back to completely stock.:bs I'm thinking Magnuson Moss Act violation. Anyway, have any of you guys had this problem? 492 I mean..I can deal with the dealer once I show the code is not header related. Do you replace the "air valve"? Sorry for the long post and thanks. |
That pinching, somewhat uncomfortable feeling you have is...
The car is an '04 Z06 with long tube headers and Bassani exhaust from the headers back. The car also has a Vinci installed cold air intake, cooling upgrade and tune as well. All of the mods were done ~3000 miles ago and the car has run great. Last week I got a check engine light. It turns out the code was 492 which apparently is somewhat odd. Bank 2 secondary air intake i.e. air valve. I checked with a chevy tech before I took the car to the local dealer and he indicated the code usually shows up after the car has sat for a while and some rust from water vapor triggers it and it has nothing to do with the headers etc. The car has 7400 miles on it so I took it to the dealer for the warranty repair. Guess what? Surprise, surprise. Oh we can't fix that unless the car is taken back to completely stock.:bs I'm thinking Magnuson Moss Act violation. Anyway, have any of you guys had this problem? 492 I mean..I can deal with the dealer once I show the code is not header related. Do you replace the "air valve"? Sorry for the long post and thanks. Charlie |
I have a very cooperative dealer who has warratied some really questionable stuff. It is up to the dealer and his attitude toward you and your car.. The factory would have no problem but you have to get thru the dealer filter.
Having said that I would just pull all that crap off and the pump too. It is useless and will not be missed other than you will need to edit out codes. |
Thanks folks. I am an attorney so the legal part is no problem. The factual part is what I am trying to confirm. If headers set a 492 code (which I am sure they don't) wouldn't we all get the code? It apparently is pretty rare. Also 3000 miles for it to start setting a code. That also sounds very unlikely. As far as the warranty issue is concerned they can only deny warranty repairs if the part that failed can directly be attributed to the modification. That is one of the items that the warranty act was designed to prevent. Any others with this code?
I really find it interesting from my search on the forum that dealers are using intake mods to deny 492 warranty claims also. Intake, exhaust, clutch widgets, throttle clutches...dealers will say anything won't they? This is why I need help proving that the code is not from the headers. |
Clear out the DIC.
Originally Posted by will82
Clear out the DIC.
http://www.gearchatter.com/viewtopic10679.php |
From reading the explanation of the DTC codes, it does appear that your headers *may* be contributing/causing the issue. If your O2s are reacting quickly enough it looks like they may be able to set the DTC.
Thanks again. I am in Orlando. Like I said, if the mods are causing the problem then factually the dealer is correct. I just find it very hard to believe that no code for 3000 miles and then all of a sudden it throws a code and it is not related to the sensors performing improperly but heh, if that is the deal then so be it and I will figure out how to remedy it outside of warranty. Like I said it is the factual part I need the help with.
Intake and exhaust causing the code? Seems odd. Check this post out. http://forums.corvetteforum.com/show...&highlight=492 |
The dealer has every right to deny the claim based on the header install and quite frankly correct in his assessment.
The Mods installed significantly impact the AIR system and hence the code and problem. Phil |
I really find it interesting from my search on the forum that dealers are using intake mods to deny 492 warranty claims also. Intake, exhaust, clutch widgets, throttle clutches...dealers will say anything won't they? This is why I need help proving that the code is not from the headers. "The Magnusson-Moss Warranty - Federal Trade Commission Improvement Act of 1975 protects consumers from such fradulent activity by new car dealers. Under this Act, aftermarket equipment that improves performance does not void a vehicle manufacturer's original warranty, unless the warranty clearly states the addition of aftermarket equipment automatically voids your vehicle's warrany or if it can be proven that the aftermarket device is the direct cause of the failure. The easiest way to check this is to look in your owner's manual under, "what is not covered". Under Magnusson-Moss Act a dealer must prove, not just vocalize, that aftermarket equipment caused the need for repairs before they can deny warranty coverage. If they cannot prove such claim-or offer an explanation- it is your legal right to demand compliance with the warranty. The Federal Trade Commission (202.326.3128) administers the Magnusson-Moss Act and monitors compliance with warranty law." |
2000, I agre, but in practice if I just want the car fixed the burden, as you know, kind of shifts. Likely, another area dealer will be glad to fix it under warranty and this dealer will lose my business forever. We will see but thanks for the help.
For those trying to claim that the dealer was right in denying the warranty claim for fixing this issue, you were way off as I thought. The problem was a valve in the air system that was not functioning properly. Warranty item! It was fixed by a local dealer with great employees who know what they were doing. The other dealer had a
"Master tech" who was either incompetent, too lazy to properly troubleshoot or simply lacks the common sense to figure out that a problem which arose 3000 miles after the header install was not related to the headers. In any case, the dealer who has the folks that know enough and took the time to help has a new happy and loyal customer. |
Glad to hear that you got the issue resolved. There are still some good dealers out there, but the trick is to find them.
It is not up to you to prove the code was not caused by the headers, it is up to the dealer to prove to you that what you did caused the code, per Magnusson-Moss Act of 1975. "The Magnusson-Moss Warranty - Federal Trade Commission Improvement Act of 1975 protects consumers from such fradulent activity by new car dealers. Under this Act, aftermarket equipment that improves performance does not void a vehicle manufacturer's original warranty, unless the warranty clearly states the addition of aftermarket equipment automatically voids your vehicle's warrany or if it can be proven that the aftermarket device is the direct cause of the failure. The easiest way to check this is to look in your owner's manual under, "what is not covered". Under Magnusson-Moss Act a dealer must prove, not just vocalize, that aftermarket equipment caused the need for repairs before they can deny warranty coverage. If they cannot prove such claim-or offer an explanation- it is your legal right to demand compliance with the warranty. The Federal Trade Commission (202.326.3128) administers the Magnusson-Moss Act and monitors compliance with warranty law." |
Congrats on finding a dealer you can deal with, sometimes you just have to look around. When I bought my F-250 diesel truck, one of the questions I asked was how they felt about chips, and mods in general. One dealer told me, no problem, and he would even install the chip for me. I bought the truck from him right then.
Originally Posted by Mike Mercury
the words are fine & dandy. But it real life... you'll have to prove that the aftermarket equipment did not cause the need for repairs. The dealer only needs to suspect - and they get out of it. Just like the post originator found. It's easier to keep trying different dealers in hopes of finding one that is mod friendly - then to pay a lawyer to get the rights promised in the MMWA.
It is just nice to find a good honest dealer with folks you can trust with your car. It is a plus when they are corvette people. While I am an attorney I sure don't need to fight over something this minor. It is just a pain in the rear to deal with some of the ignorant folks at some of the dealerships. This is why I do most of my work on my cars myself. Thanks again for the comments of those that understood the problem.
Originally Posted by 2000C-5
Even if they were to have to fix the problem, you never know what happens to your vehicle when you aren't looking.
My granddaddy told me there were two people you NEVER wanted to pi$$ off. One is the guy fixing your car unless you're going to stand there and watch EVERY move. The other is a waiter or waitress unless you are going to go into the kitchen and watch the food being prepared and escort the server back to your table. About 40 years ago, I had a friend who worked at one of the national restaurant chains that served a variety of meats and vegetables. He chewed tobacco. There were no spittoons in the kitchen. I still will NOT eat mashed potatoes at Shoney's. Charlie |
