How many amps for a fuel pump
I am installing a toggle for the electric fuel pump, will a 20 amp switch be enough?
Take a look in your fuse box...I think it's 10 amps.
Since the factory fuse is 10 amps, i would think 20 amp switch is more than enough :)
If you use the switch to close the circuit on the primary side of the relay, it can be even smaller, still.
RACE ON!!! |
thanks
