Anyone know this block GM 41 3970010
I know its a 350, (I believe), has a drivers side dipstick and a "8" for its build year. I would think 1978 cause the small pad in the front of the engine is the smaller square shape not the longer more narrow older style pad for 1968. The pad is smooth so theres no engine codes. Its cast GM 41 by the 3970010. I thought it was an L-48 but I know they had a rh dipstick. Thanks for any help.
Yes, it's a 350 cid block, hi-performance application. Those ones were manufactured by GM between '68 - '76, but were being manufactured after that in Mexico. The Mexican blocks have the "Made in Mexico" raised letters next to the casting number.
Originally Posted by mts7900
(Post 1558630428)
Originally Posted by John 65
(Post 1558630563)
Thanks for your help, It dont have the Made in Mexico script on it, but with the 8 for the year it was cast (78 I would think cause of the smaller pad so it cant be a 68) and the lack of the mexico script I am still a little confused. Date on rear of rh side of block says J 7 8 Thanks
HI GUYS
Looking through my 1965-69 chevrolet by the numbers book this block came into production sometime in late april or early may of 1969 and was used through 1975.It was produced in 2 and 4 bolt application except for 1969 which were all 4 bolt main.They also explain that the date should have three digits,is there a digit that maybe you don't see.Or maybe not everything in this book is true. |
J 7 8 is an October 7, 1978 Flint block (the 3970010 block was only cast from 1969-1979 - about seven million of them); it was used in every conceivable car and truck application. :thumbs:
I guess while i was typing you added j 7 8 which means j=october 7=7th day 8=1968
There should be an engine code stamped on a block pad located immediately forward of the right hand cylinder head.Then maybe we can figure this out.
Sorry if i caused confusion |
Thank you all for your replys, unfortuntaly the pad is smooth, no codes. I guess I dont have anything special out there under the hood :lol: I questioned it cause I would have sworn the dipstick was on the other side for that year. Appreciate all your help.:thumbs:
Originally Posted by Howy
(Post 1558632535)
In my experience, the "010" block is the most common pre-87 block. They were used in the last 302 and 327 motors, as well as hundreds of thousands, if not millions, of 350s. I have a 69 4-bolt version as well as a 77 2-bolt.
Some had a higher tin and nickel content, designated by 010 and 020 cast into the block to the left and right of the front and rear cam journals. I believe these were mostly used for the 302 and LT1 350s, but some may have been used in trucks. BTW, one of David Vizard's books says the 010 block was made from 68-79. Mortec.com shows 69-80. :confused: |
Thanks everybody for your help.:thumbs:
I just blew up one of these blocks (2 bolt main version). I am pretty sure the 2-bolt main versions were used in low performance applications, 4-bolt mains used on high performance.
Originally Posted by tangel2
(Post 1558646300)
I am sure they are not "high performance". :D |
3790010 on my vette
What do I have there is no number or codes on block
Maybe the block was decked/squared up in a previous rebuild which would have removed the stamping on the pad. Is it a standard bore?
This is a nearly 12 year old thread, guys.
Casting codes
I have a 3970010 block. Need to know year what car. Have 2 of them.
V40416tyz C7f441412 V0402tfm C94160394 Can anyone help me out Both r 4 bolt main |
Goodness.
2007 thread still survives. Start new threads guys. |
Originally Posted by Easy Rhino
(Post 1599945346)
Goodness.
2007 thread still survives. Start new threads guys. as I've been looking through this thread, I seem to have a question. I just bought a motor for street stock dirt racing. Motor is a 3970010, 010 stamp, a ck227? Stamp, along with H24 WR and a g12, then a bear the harmonic balancer, V1203cmb, punched in the block with 58750607 stamped onto that, can anyone figure this mess out, I believe it's a 350 made in flint engine co. On Jan 20? 1973 maybe? And according to the CMB, A 350 from a truck, 2 bolt main..please help |
