Blower Motor Removal Instructions?
My AC started making a ticking noise that is blower fan speed sensitive. I assume either the bearings are going out or something is stuck in the fan. I don't have a service manual but I'm hoping someone here is kind enough to scan the procedure to pull the blower fan/motor? :blueangel:
On a separate note, if I bought a subscription to AllDataDIY.com would they give me instructions? $25/yr seems pretty good if they really do have all the diagrams and instructions they claim to. |
Originally Posted by bomax
(Post 1559147146)
On a separate note, if I bought a subscription to AllDataDIY.com would they give me instructions? $25/yr seems pretty good if they really do have all the diagrams and instructions they claim to. PM Member Bill Curlee as I remember him posting a how to a while back. |
(Post 1559147146)
On a separate note, if I bought a subscription to AllDataDIY.com would they give me instructions? $25/yr seems pretty good if they really do have all the diagrams and instructions they claim to. The blower motor is 3 screws, a hose, and the electrical connector. It's hanging on the far right passenger side under the dash. Two of the screws are easy, the back one is a bit of a pain. The hose will pop right off, just make sure you remember to reconnect it. Personally, I'd spring for the factory service manual. |
the connector is a bit of a pita also
they often squeak, some WD40 soaking and good to go |
Thanks guys. It ended up being two small leaves. Damn them... I will never know how they got in there, but at least they're out.
Interestingly, I was feeling around and felt the heater core, which seemed in good shape (or at least felt like it :lol:) but did not smell at all. I mention this because I've been having a vent odor issue for awhile, and I figured this would be my big chance to fix it once and for all. Instead, the mystery just got deeper. The blower motor/vent area/heater core all smelled 100% fine. Up near the cowl area (outside the car) I can smell it though. I've felt up in there too (my arms and hands hate me at this point) and couldn't find anything, although the smell is definitely strong. I've removed the plastic cowl piece to no avail. I've done all the sprays there are. :( |
Check your AC drain line for a build up of gunk. Also I believe there was a TSB on this... I think. There's a sticky with all the TSBs listed, you can peruse em at your leasure! :thumbs:
