Does anyone have a longer term usage with results to post?
Originally Posted by toasted
(Post 1564735342)
As far as the pro-street bracket goes, it's only been available for a few months. I have had some emails off site from non-members who have done it, but we're still talking only 2-3 months tops. -- Joe |
Ok will do. Thanks Joe.
:bump: anyone have a road test report of a T5 swap?
I'm still collecting parts for my swap. |
Originally Posted by VtVette
(Post 1565005544)
I'm still collecting parts for my swap. -- Joe |
Sadly I've still not gotten my exhaust squared away enough for a road test. Work and such, y'all know how it gets sometimes...
Originally Posted by anesthes
(Post 1564735362)
Theres 1 or 2 guys who made their own bracket. If you search, you'll find one of them still posts here. Hes got a couple years of use out of it.
Originally Posted by BTTB
(Post 1565013075)
Ive had Pro Streets t-56 conversion in my 86 for over two years now and couldnt be happier. Ive got alot of hsp and have not been gentle on the car and its just as solid as the day that I installed it. As far as the t-56 goes I havent ever heard of anyone blowing one ,thats the reason that I chose it over the zf-6,-- + too many syncro problems and to expensive to rebuild.:cheers:
I agree with the ZF6 stuff. The ZF6 was also more of a PITA to install on my car, required more cuttings and more expensive parts, the clearances all the way up to the stupid starter are absolutely insane. AND they shift goofy. -- Joe |
Joe, have you completed your ZF6 swap using 4+3 hydraulics? How does it feel? You gonna do a T56 next?
Originally Posted by JLeatherman
(Post 1565013404)
Then the starter bit me. If the block is like a few thousands different than a production LT1, the starter is a PITA to bolt up. My ZF6 swap ended up costing about $1800. Stick with the T5... I'm gonna run it until it explodes. When it does I'll push it in the river and buy a C5.. -- Joe |
They make a kit for the T5
Last week a guy posted a web site prostreetcustoms.net
They make a kit for the C4 T-56 & the T-5 Transmissions. I would go with the T-56 / 6 speed myself Also, I went to the web site to look at their Truss Bar. Iam going to order one next week. I talked to the the owner Tom and he said the he has enough stock to make 23 bars and he's going to stop making them. He say's It's getting harder to have the rear locators made. GM stop making them. So if you want to buy one, you better order it soon. :cheers: |
Originally Posted by hangonsnoopy
(Post 1565025206)
They make a kit for the C4 T-56 & the T-5 Transmissions. I would go with the T-56 / 6 speed myself Also, I went to the web site to look at their Truss Bar. Iam going to order one next week. I talked to the the owner Tom and he said the he has enough stock to make 23 bars and he's going to stop making them. He say's It's getting harder to have the rear locators made. GM stop making them. So if you want to buy one, you better order it soon. :cheers: -- Joe |
(Post 1565025206)
(Post 1565025834)
It was a bit more work than I expected, but not that bad and I got the whole thing done for less than $500.
And I'm not talking crap either, I've done the T5 AND the ZF6 swap. The ZF6 swap is a pita and it costs way more, 6th us useless as you suggested without a rear-end swap, etc. Don't listen to the "bogus" guys on 'the other site'. Half of them don't do their own mechanical work.. -- Joe |
hey I have the t-5 in the car now didnt do the shifter yet, but have been taking it out a few times without the boot and center piece in, WOW this car is so much more fun hits second way harder than it used to, way more fun since the swap.
(Post 1565026375)
And that's really the whole point right there. For 4+3 guys looking for something better to replace the 4+3 on the cheap, a T5 is the way to go.
And I'm not talking crap either, I've done the T5 AND the ZF6 swap. The ZF6 swap is a pita and it costs way more, 6th us useless as you suggested without a rear-end swap, etc. Don't listen to the "bogus" guys on 'the other site'. Half of them don't do their own mechanical work.. -- Joe Taking out the 4+3, along with adding C5 brakes really changes the 84 especially with Z51 . |
Originally Posted by Dominic Sorresso
(Post 1565357201)
Well I don't doubt the T5 is a good swap, but I did my own ZF-6 swap, in the winter, on my back and in the garage. Installed Fidanza while I was down there. Never regretted it. Added a Hurst to it and 3.45 D44 rear. Really nice combo. 6th gear gives you thr option of some shorter rear gearing.
Taking out the 4+3, along with adding C5 brakes really changes the 84 especially with Z51 . Overall I'd rather have the ZF because I do think its stronger, and it sorta just 'belongs there'. The swap didn't cost me anywhere near what folks say though. $1500 is a joke, it cost me closer to 2k when I was done. Maybe $1500 for everything used and near non-functioning condition. I had to buy new hydraulics, a hose, new clutch, flywheel, ZR1 pivot for flywheel, then a starter cuz the stupid offset BH. I still think they shift kinda goofy though, and it sounds like rocks in a clothes dryer at idle. really bad.. Of course, my 16lbs singlemass flywheel and unsprung clutch disc and the fact that it's a black tag ZF6 don't help. -- Joe |
shifter is done, it looks sweet will try get some pics soon
Originally Posted by 1984corvette
(Post 1565449521)
Can't be any worse than the ZF6 shifter though. The thing shifts from 1st to 2nd like the shifter on a riding mower. -- Joe |
